Paint Question
#2476739
04/03/18 01:19 PM
04/03/18 01:19 PM
Posts: 608 TN
1DGEMAN
TN
Has anyone here ever used Rustoleum paint on a car body? Would it hold up? At $26.00 a gallon it is real inexpensive. Thoughts? Obviously this would not be on a restored car just a driver.
Real Men shift for themselves
Re: Paint Question
[Re: 1DGEMAN]
#2476800
04/03/18 03:25 PM
04/03/18 03:25 PM
Posts: 957 Chicago
PurpleBeeper
Chicago
1. Rustoleum makes about 75 different paints, so which one? 2. In general, polyurethane (exterior-type, hardener should be MDI aka polymeric methyldiiosocyanate) will not fade in sunlight. Acrylics hold up well to sunlight too, but I don't believe Rustoleum sells those. 3. Rustoleum sells industrial paint (+ spray paint). Industrial paint is usually designed to go on VERY thick compared to automotive paint (like 40-120 mils industrial vs. maybe 5 mils automotive paint). 4. Industrial paints are very, very rough compared to automotive paint.....so it won't be all that shiny or have an automotive "luster" to it. Smooth = shiny (for glossy paints) 5. The big advantage of automotive paint is that it has a partA/partB (similar to industrial paint...lasts longer), is baked in a booth (lasts longer) and is applied in a dust-free paint booth (dust is EVERYWHERE in the air).
If I had to go cheap (I've seriously considered this), I would buy some automotive paint from a true body shop supplier, build a paint booth with plastic tarps inside a well-sealed garage, use a respirator (change cartridges every fender & only stay inside booth for one fender at a time....you need air after all), and try to set up some EXPLOSION PROOF heat lamps. Regular ones will "go boom" with the paint vapor in the air.
It used to be a little easier to paint your own car with lacquer paint (no part B), but those are all gone due to solvent limitations (VOC) in most states. They don't last as long, but they air dry and you don't need heat lamps.
Without a spray booth, you WILL get a lot of dust/dirt in your paint.
For me, I am doing all of the bodywork/sanding/metal etch priming/filler-type priming/trim removal/edge painting with rattle cans myself. I plant to let Maco or somebody cheap do the final tack-cloth/tape off/paint so they can bake it in a booth. That's about as cheap as I can figure to do it & have it turn out "decent". Oh yeah, I have a compressor & gravity gun for the primer coats.
70 Roadrunner convt. street car
440+6, NOS, 4-spd, SS springs
'96 Mustang GT convt. street car
'04 4.6 SOHC, NOS, auto, lowered
"Officer, that button is for short on-ramps"
Re: Paint Question
[Re: 1DGEMAN]
#2476872
04/03/18 04:57 PM
04/03/18 04:57 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
You can get much better paint for a car for under 100 bucks. Buy some single stage kirker urethane, summit brand, etc.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: Paint Question
[Re: Alaskan_TA]
#2477083
04/03/18 10:37 PM
04/03/18 10:37 PM
Posts: 608 TN
1DGEMAN
TN
Thank you very much for the link (all 900 pages lol). I think I will try it but with an HVLP gun not a roller.
Re: Paint Question
[Re: Alaskan_TA]
#2479224
04/08/18 02:59 AM
04/08/18 02:59 AM
Posts: 8,779 Mt.Gilead, Ohio
OhioMopar
Mt.Gilead, Ohio
I had no idea that thread was still around...
1969 Dart GTS 340 1969 Super Bee X9 N-96 1969 Coronet R/T X9 N-96 2015 Dodge Dart GT 2019 Ram 2500 Big Horn. Looking for the original block for my Bee. The last 4 are 7449
