Re: six pack carb question
[Re: Tommy383]
#2476601
04/03/18 01:40 AM
04/03/18 01:40 AM
Posts: 1,809 North Dakota
Azzkikrcuda
North Dakota
A few things, Those carbs are mechanical not vacuum, fuel inlet on the drivers side I believe and chevy linkage. Will bolt up to six pack intake and can be made to work.
The only Carbs I care about are under the hood!
[Re: Morty426]
#2476667
04/03/18 10:25 AM
04/03/18 10:25 AM
Posts: 4,733 Moved to N.E. Tennessee
GomangoCuda
The outer carbs have metering blocks instead of metering plates. The rear one will not fit on a mopar intake unless you change to a side hung float bowl.
[Re: 62maxwgn]
#2476723
04/03/18 12:40 PM
04/03/18 12:40 PM
GomangoCuda
Here is the outer carb. Bowl will not work on rear carb. Also venturi and throttle bore are smaller than mopar type carbs. Booster is also the type commonly found in smaller carbs. Hmm, it has an air horn that might interfere with a mopar aircleaner lid. Center carb linkage will not be compatible with mopar throttle pressure linkage. These are not at all the same as the 4782/4783 aftermarket mechanicals pictured above.
[Re: Tommy383]
#2476806
04/03/18 03:32 PM
04/03/18 03:32 PM
Posts: 960 Chicago
PurpleBeeper
Chicago
Uh, yeah....what these guys said. Find some Mopar carbs.
70 Roadrunner convt. street car
440+6, NOS, 4-spd, SS springs
'96 Mustang GT convt. street car
'04 4.6 SOHC, NOS, auto, lowered
"Officer, that button is for short on-ramps"
