Re: 1970 Super Bee 440-6 leaf spring advise needed...
[Re: Cuda340]
#2474306
03/30/18 11:39 AM
03/30/18 11:39 AM
Posts: 4,453 Morristown Tn.
71birdJ68
Morristown Tn.
Rearch, and restore. Also, it depends on the level of the resto that you do on the rest of the car.
[Re: Cuda340]
#2474349
03/30/18 01:18 PM
03/30/18 01:18 PM
Posts: 9,550 Sacramento CA
Morty426
Sacramento CA
The car is being restored to a high level, not concourse high, but I want to make the car as original as possible. Jeff, I have two 70 sixpack Bees - both have their original springs and sit at a good height. I would go ahead and restore the springs as is unless you know the car had a rough race history or was used to store gold bars in the trunk. M426
[Re: Cuda340]
#2474493
03/30/18 06:14 PM
03/30/18 06:14 PM
Morty426
Sacramento CA
Thanks Morty. Are your springs painted black or natural? Jeff, It's really hard to tell unless you have the springs out of the car and unassembled. Both my cars have been off the road for a long time; 1973 and 1983. Both are from Lynch Road. Looking at the springs in the car I would say they are natural. M426
[Re: Cuda340]
#2474815
03/31/18 11:36 AM
03/31/18 11:36 AM
Posts: 957 Chicago
PurpleBeeper
Chicago
As original as possible, put your original springs back on. I "think" they came with thin zinc sheets between the leaves (prevents corrosion) and I believe those are reproduced now. You could always call ESPO or another spring manufacturer or my Dr.Diff for advice too.
70 Roadrunner convt. street car
440+6, NOS, 4-spd, SS springs
'96 Mustang GT convt. street car
'04 4.6 SOHC, NOS, auto, lowered
"Officer, that button is for short on-ramps"
[Re: PurpleBeeper]
#2474947
03/31/18 05:03 PM
03/31/18 05:03 PM
Morty426
Sacramento CA
As original as possible, put your original springs back on. I "think" they came with thin zinc sheets between the leaves (prevents corrosion) and I believe those are reproduced now. You could always call ESPO or another spring manufacturer or my Dr.Diff for advice too. IIRC there are plastic pieces and zinc plates between the springs. The plastic keeps them from squeaking
[Re: cdp]
#2475318
04/01/18 01:01 PM
04/01/18 01:01 PM
Morty426
Sacramento CA
disassemble and soak in some evaporust solution. Once done, they will look like new. Seal with RPM. Reassemble. EXACTLY!!!
[Re: Cuda340]
#2475852
04/02/18 05:27 AM
04/02/18 05:27 AM
Posts: 1,655 Cut and Shoot, TX
kentj340
Cut and Shoot, TX
How to tell if the springs were originally bare metal or painted black: Find remnants of the original latex paint daubs on width of top leaf at 10:30 on left front spring eye, or 1:30 on right. This area is the most protected from the elements and road debris, but any latex is usually invisible until cleaned non-abrasively. If cleaning with fresh Evapo-Rust, only soak for 1-2 days to preserve the latex - more time will remove it. After checking for latex you can re-immerse the leaf for more rust removal, if needed. Carefully check under adhering latex paint and on the back side of latex paint chips for black paint. If none, the springs were bare metal. The latex paint daubs would have been a last step in spring production, after assembly and any black painting. My 160,000 mile springs had black paint on the top side of the latex paint chips, indicating a spring shop had painted them black, not the factory. For original bare metal appearance of hot rolled, heat treated steel bar for leaf springs, use gun bluing followed by RPM. See: https://board.moparts.org/ubbthreads/ubbt...tml#Post2454941In my experience with gun bluing, the final color is more black than blue. Repeated wetting with solvents such as acetone or lacquer thinner and wiping with a clean rag will slightly darken the gun bluing. Photo shows strut rods cleaned with Evapo-Rust, then cleaned with mineral spirits, and treated with gun bluing. The top one was further cleaned several times with acetone or lacquer thinner before bluing, and the bottom one was cleaned only with alcohol before bluing according to the bluing directions. Unfortunately the lighting was yellowish fluorescent.
