15x10 #247382
03/08/09 09:56 PM
03/08/09 09:56 PM
Ma
Voluster Offline OP
Voluster  Offline OP
Ma
Will a 15 x10 5.5 back space fit under a F body with a b body rear?
Has caltracs and stock spring location
Phil
Re: 15x10 [Re: Voluster] #247383
03/09/09 11:58 AM
03/09/09 11:58 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I don't think it will make it with the stock spring location. Mine has 3.5" backspace 10" wheels with an A-body width axle. Do the math it should be about the same. I moved the stock front hangers flush to the frame by drilling new holes. I also had to hole saw a hole for the front spring bolt head. The rear shackle hanger can be moved anywhere you want. Just remove the rear bumper shocks and you can reach inside the frame. Drill new holes and your alll set. The biggest stumbling block is the front inner wheel well. It has to be moved inward. Go back in my old posts ,there are pictures of how I did it.
Doug
