1978 D150 roof replacement any sources? #2473501
03/28/18 08:10 PM
03/28/18 08:10 PM
Port Saint Lucie, FL
ChallengerGary Offline OP
I found a cool old truck - 1978 318 manual long bed. The worst part that I can see is the roof is pretty bad over the passenger side. Does anyone make replacement roof sections or am I stuck either trying to find a decent one or getting creative with sheet metal?
00S0S_a5IgmRZYpXZ_1200x900.jpg00404_fjnqkWO8fbx_1200x900.jpg00x0x_3ITHxw6p63w_1200x900.jpg
Re: 1978 D150 roof replacement any sources? [Re: ChallengerGary] #2473524
03/28/18 08:45 PM
03/28/18 08:45 PM
Guitar Jones Offline
You're stuck. You can find plenty of the newer style single cabs rust free but that style, like my 92 club cab is much harder to find.
There are three panels in there and they rust from the inside out. I have located a roof for mine, it's not rust free but it's close. I'm going to start the surgery on my truck this summer. I'll take pics and will post a thread either here or at DTR or maybe both.
You could replace your whole cab with a newer style rust free one though. Just be sure to treat it very well so it doesn't rust as well.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: 1978 D150 roof replacement any sources? [Re: ChallengerGary] #2473606
03/28/18 11:11 PM
03/28/18 11:11 PM
5thAve Offline
5thAve  Offline
Not that it matters since the roofs are the same but that's the 1979/80 front end.
Re: 1978 D150 roof replacement any sources? [Re: ChallengerGary] #2473669
03/29/18 01:54 AM
03/29/18 01:54 AM
Canada
demon Offline
demon  Offline
Canada
That truck is a 79.
Roof fits 72-80.
You could change the outer skin and drip rail from a parts truck.
It will most likely need the inner skin and possibly the header too.
If you are capable, it's not a difficult repair.
Find a junkyard truck, saw through the pillars, bring the chunk home and carefully disassemble it.
But look at the floor and rockers and decide if it's clean enough to do the work to, or if you should swap a cleaner cab on.
There trucks are super easy to work on
Re: 1978 D150 roof replacement any sources? [Re: ChallengerGary] #2473723
03/29/18 09:22 AM
03/29/18 09:22 AM
ohio
ruderunner Online content
ruderunner  Online Content
ohio
Gj, must be a Florida thing. In my area the flat roof trucks have less rust out than the peaked roof trucks (81-93 regular cab) Even the 70's roofs are easier to find.
To the op, 72-93 regular cab truck are all donor candidate, 81 up has a crease above the windshield but it's strictly cosmetic.
If you want to do it factory style at the spot welds, be prepared to take a big chunk of the cab apart.
Angry white pureblood male
Re: 1978 D150 roof replacement any sources? [Re: ChallengerGary] #2473733
03/29/18 10:01 AM
03/29/18 10:01 AM
scratchnfotraction Offline
I patched mine with sheet metal and formed a new section of drip rail.
I slide a flat sheet in, weld to roof skin, weld to frame. bent and trimed to form new drip rail.
but mine was no where that rusted and it was a 91 cab going on my 85 truck
did I mention it took me from july to December to get it and the floor patched first? and I leaned to weld sheet metal for the first time LOL!
GOOD LUCK! and find paint & body man as your NEWEST BESTEST FRIEND.
that was the best thing I did and now both trucks are painted and rust free.
just purchased a 95% rust free 86 cab from my local recycler for 150 bones to start my gasser truck build.
IIRC there is a 73 cab there that you could buy or chop if interested shoot me a PM.
I know all the glass/doors are gone so chop saw the whole top off for cheap.
Re: 1978 D150 roof replacement any sources? [Re: ChallengerGary] #2473734
03/29/18 10:06 AM
03/29/18 10:06 AM
is it a manual 3 speed (3 on the tree?) long bed?
have not seen a 3 speed manual truck in yrs myself.
Re: 1978 D150 roof replacement any sources? [Re: scratchnfotraction] #2473778
03/29/18 12:11 PM
03/29/18 12:11 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I have a nice rust-free club cab roof already cut off, won't do you any good though. shruggy
JB Rhinehart, Realist
A-Body's RULE!
Re: 1978 D150 roof replacement any sources? [Re: ChallengerGary] #2474255
03/30/18 09:39 AM
03/30/18 09:39 AM
man! a club cab roof and a RC/TD roof are gold. single cab roofs a silver turning to gold.
Re: 1978 D150 roof replacement any sources? [Re: ChallengerGary] #2474405
03/30/18 02:52 PM
03/30/18 02:52 PM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
Best bet is to find a donor cab and use the roof, if your good with metal work, they are not that hard to fab, With an English wheel , you can pop out a replacement roof section, and a stretcher/shrinker you can do the fence and inner support panel.
A pillar....been a long time but I've used F-body(with some serious work) to graft in on a few trucks back in the 90s
With Time and effort you can save anything if you have the tools.
Truth has no agenda, but those with an agenda make their own truth.
Some of us are so open minded they only see their View
Re: 1978 D150 roof replacement any sources? [Re: ChallengerGary] #2474533
03/30/18 08:07 PM
03/30/18 08:07 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
maybe www.car-part.com
Cool truck btw.
Facts are stubborn things.
Re: 1978 D150 roof replacement any sources? [Re: ChallengerGary] #2491611
05/03/18 06:01 PM
05/03/18 06:01 PM
Well, truck did not end up happening anyways. Seller disappeared
