Re: Adjusting ladderbars help.verifying preload.?
[Re: 70satelliteguy]
#2473428
03/28/18 06:10 PM
03/28/18 06:10 PM
Posts: 11,600 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Little or no preload means there is no bind or tension on the suspension links that would influence the corner weights. If you can slide the bolts in an out that easily, and/or if the adjuster is loose enough to wiggle by hand (no load on it), that's pretty close. Corner weights are a separate issue and are influenced by where the weight (fuel tank, batteries, driver, etc.) is distributed in the car, and spring loads. Neutral preload and equal weight on the rear corners is great. Should be easy to get it to go straight and square.
As far as having to pull the bars fore or aft to get the bolts in, the rear should be perpendicular to the centerline of the car. This is adjusted by running the front links in or out of the bar. If the rear is square, don't fool with them.
#2473720
03/29/18 08:58 AM
03/29/18 08:58 AM
Posts: 4,243 Charlotte, North Carolina
sgcuda
The fact that you need to apply equal work to either side when installing the bolts shows that the ladder bars aren't preloaded. You have to pull down, probably because the coil overs are mounted in the rear and the axle is becoming the pivot point due to the weight on the car, causing the front of the ladder bar to rise. I think it's fine. I would have your shop do a four wheel alignment and find out if the rear axle is squared to the front (thrust line) and get it to less than .5 degree. This should be done before adjusting your front end toe.
[image][/image]
[Re: sgcuda]
#2473722
03/29/18 09:10 AM
03/29/18 09:10 AM
Posts: 10,010 Frostbitefalls MN (Rocky&Bullw...
gregsdart
The fact that you need to apply equal work to either side when installing the bolts shows that the ladder bars aren't preloaded. You have to pull down, probably because the coil overs are mounted in the rear and the axle is becoming the pivot point due to the weight on the car, causing the front of the ladder bar to rise. I think it's fine. I would have your shop do a four wheel alignment and find out if the rear axle is squared to the front (thrust line) and get it to less than .5 degree. This should be done before adjusting your front end toe. I agree.
[Re: dvw]
#2473803
03/29/18 12:59 PM
03/29/18 12:59 PM
Posts: 1,301 Penna
70satelliteguy
Penna
I have weight in drivers seat equal to driver. Front torsion bars are adjusted to have equal height on front end. I have the car currently on my scales and adjusted to equal weight on rear tires. rr 842 lr 838. rf 923 lf 944. I just installed new Double adjustable QA-1 coilovers and new springs. I have my local guy do 4 wheel alignment before going to the track. I just wanted to verify that I do not have preload on either tire. the car seems to like it that way. I was also concerned that I might have some binding of the bars since I have to move the bars around some to get the bolts back in. They don't just slide back in easily as is often described. Thanks Mike
#2473814
03/29/18 01:31 PM
03/29/18 01:31 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
1/8" movement isn't much. Both bars going the same direction is also an indication. "Easily" means you can pull it the 1/8" with one hand, a few pounds of force, and not work up a sweat. Pre-loading ladder bars will sometimes get into floor jacks and pry bars to get them back together. I wouldn't want the bolts to fall in or out of the holes. A little wiggling is normal.
If your alignment shop does a 4-wheel and says it's square, that's better than rolling around on the floor with tape measures and plum bobs.
What kind of 60's? I don't know your combination, but looking at those corner weights, I'd take the thing to the track and let the car tell you if anything needs to be tweaked. I would expect it to be real close unless it's really quick.
#2473959
03/29/18 06:45 PM
03/29/18 06:45 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Well, preloading, or lack of it, is mainly concerned with going straight and square, not so much going quicker. Although smooth, straight and square is the quickest method. Going into the 1.20s with a ladder car, I would expect to need to run those shocks fairly tight.
#2474836
03/31/18 12:15 PM
03/31/18 12:15 PM
Posts: 9,847 MI, usa
dvw
MI, usa
My weghts are with-in 30lbs right to left with no preload. The car needs 5 flats. With that it goes dead straight. My 10.20 car never cared. This car (9.0) it's a huge difference. Doug
[Re: dvw]
#2474855
03/31/18 01:04 PM
03/31/18 01:04 PM
Posts: 52,972 Romeo MI
MR_P_BODY
On my car(4 link) I had 12# of preload and it drove straight as a arrow.. that wasnt even 1 flat.. I just turned it by hand.. was very EDIT On my Rampage(ladder bar car) I have less than a flat in it also
#2474867
03/31/18 01:42 PM
03/31/18 01:42 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Preload is the intentional binding and loading of the suspension links. Some is fine, but I prefer to use as little preload as I can in order to avoid that and allow the suspension to work as freely as possible. If it goes beyond what I can do without a wrench to turn the links - usually a couple of flats - I will use other methods to get the weights close to where they need to be and use the bars to dial in the last few pounds. If we have some load in it and need some taken out once we get to the track, it's easy to just tweak a bar some.
#2474881
03/31/18 02:06 PM
03/31/18 02:06 PM
Posts: 19,372 Las Vegas
Al_Alguire
Las Vegas
One other thing that OFTEN gets overlooked when putting a car on scales is tire pressure. Make sure the tires aired up to where they will be on track. A few pounds can make a big difference. Also preload will be different on every car to get it to go straight. Generally the more power the car makes the more preload it will require, that's a universal statement but holds true more often than not.
FWIW the Vette is a ladder bar car, very short ladder bars at that. We have been 1.13 60' and we know there is more let. We don't make a ton of power as its just a SB but it works well and could not be in a worse car in terms of platform for a racecar.
[Re: racerhog]
#2474911
03/31/18 03:15 PM
03/31/18 03:15 PM
MR_P_BODY
Just remember that any pre-load you add will be the opposite when you let off the pedal on the big end.. so try to add as little as possible to keep things happy but make it go straight
#2474930
03/31/18 03:56 PM
03/31/18 03:56 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
There is no universal number as far as what each corner should weigh. As power goes up weight generally needs to be moved. Big power can require the car to be neutral or weight being moved to the left rear. Scaling allows you to establish a baseline. The car will tell you what it wants from there.
If you have a car you're familiar with or a personal car, scaling the car after it's been sorted, just as it sets with no driver, and recording the information, will save time. It will allow you to put the car right back after having something apart or replacing parts without having to load ballast in the drivers seat. Typically I record with and without numbers. Unless the usual driver gains or loses a bunch of weight, it works out fine.
