Re: Kirkey seats in a stock floor board e body
[Re: Uncle Barry]
#2472658
03/27/18 10:04 AM
03/27/18 10:04 AM
Posts: 34,947 S.E. South Dakota !
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
If you do install, make sure you at least put some type of metal on bottom side so the bolts don't pull thru the stock floor if something bad may happen
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
[Re: Uncle Barry]
#2472780
03/27/18 02:45 PM
03/27/18 02:45 PM
Posts: 4,580 Motor City
6PKRTSE
Motor City
We made tubular mount in my car that tie into the factory seat holes & in addition to the frame connector/undercar bars & into the trans tunnel as well. Hard to tell but they are under there.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: Uncle Barry]
#2473184
03/28/18 07:35 AM
03/28/18 07:35 AM
Posts: 2,934 A shed in England
Tig
A shed in England
Apologies for Hijacking here but where do you guys get the carbon fibre bar covers from? TIA
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: bigdad]
#2473333
03/28/18 02:52 PM
03/28/18 02:52 PM
6PKRTSE
Motor City
Yep, Bickel is where I bought mine. I didn't really want to cover up all the blue but they do help keeping everything looking good after climbing in & out so much & the seat belts smacking off off the bars.
[Re: Uncle Barry]
#2473352
03/28/18 03:18 PM
03/28/18 03:18 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
One thing to get right is the position of the seat, also the height and lay back. Race car or street car once their bolted down you don't want to be uncomfortable . Block it up with 2 x 4 "s or anything to get it setting right then measure , drill and bolt it down.
[Re: rowin4]
#2473388
03/28/18 04:49 PM
03/28/18 04:49 PM
Posts: 52,972 Romeo MI
MR_P_BODY
One thing to get right is the position of the seat, also the height and lay back. Race car or street car once their bolted down you don't want to be uncomfortable . Block it up with 2 x 4 "s or anything to get it setting right then measure , drill and bolt it down. I'm glad you said that.. a lot of guys dont add in the lay back part and its never comfortable ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: cudaman1969]
#2473486
03/28/18 07:51 PM
03/28/18 07:51 PM
Posts: 22,722 Bitopia
jcc
Bitopia
Remember, seats need to be attached adequately but it's the seat belts that holds you and the seat in place in the event of a wreck.
I disagree with that somewhat, a seat belt holds you against the seat, it the seat moves away from the belt, the belt goes limp, defeating the belts purpose. The seat needs to be secured to incur all, if not more forces then the seat belts, in regards to anchorages, to allow both to do their job together. ![twocents twocents](/ubbthreads/images/graemlins/custom/twocents.gif)
