Re: 426 crate hemi swap into a 1967 b-body coronet
[Re: orange elephants]
#2473105
03/28/18 01:21 AM
03/28/18 01:21 AM
Posts: 15,995 RI Deep in the rust belt
chargervert
Just get a set of Schumachers Hemi to stock V8 K frame mounts and it will bolt right in,assuming that the crate Hemi has standard Hemi mounting holes in the block. They did make early crate Hemi engines with the wedge type mounting ears too. I used the Schumacher mounts to bolt my crate Hemi into my 70 Charger R/T with no issues. They are nice sturdy mounts too.
70 Charger R/T SE 472 Hemi
70 Charger R/T convertible
70 Charger R/T V Code Sixpack
69 Charger R/T SE Sunroofcar
68 Charger 383
68 Charger 318
71 Charger R/T
70 Challenger convertible
71 Challenger convertible
71 Cuda 340
09 Challenger R/T Classic
[Re: chargervert]
#2473329
03/28/18 02:45 PM
03/28/18 02:45 PM
Posts: 4,566 Motor City
6PKRTSE
Motor City
Just get a set of Schumachers Hemi to stock V8 K frame mounts and it will bolt right in,assuming that the crate Hemi has standard Hemi mounting holes in the block. They did make early crate Hemi engines with the wedge type mounting ears too. I used the Schumacher mounts to bolt my crate Hemi into my 70 Charger R/T with no issues. They are nice sturdy mounts too. Yep, I did the Schumacher Hemi mounts to 440 K-Frame conversion into my 70' Charger & everything was bolt in. Only had to ding my #1 Header tube to clear the power steering line & fitting.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
