426 crate hemi swap into a 1967 b-body coronet #2473092
03/28/18 12:44 AM
03/28/18 12:44 AM
Chattanooga, TN
orange elephants Offline OP
Chattanooga, TN
How complicated is it to swap a 426 crate hemi into a 1967 coronet 383 4-speed car? Is it necessary to change out the K-member and swap the 23 spline 4-speed for the 18 spline hemi 4-speed? The car has power steering but not power brakes.
Re: 426 crate hemi swap into a 1967 b-body coronet [Re: orange elephants] #2473105
03/28/18 01:21 AM
03/28/18 01:21 AM
RI Deep in the rust belt
chargervert Offline
chargervert  Offline
Just get a set of Schumachers Hemi to stock V8 K frame mounts and it will bolt right in,assuming that the crate Hemi has standard Hemi mounting holes in the block. They did make early crate Hemi engines with the wedge type mounting ears too. I used the Schumacher mounts to bolt my crate Hemi into my 70 Charger R/T with no issues. They are nice sturdy mounts too.
70 Charger R/T SE 472 Hemi 70 Charger R/T convertible 70 Charger R/T V Code Sixpack 69 Charger R/T SE Sunroofcar 68 Charger 383 68 Charger 318 71 Charger R/T 70 Challenger convertible 71 Challenger convertible 71 Cuda 340 09 Challenger R/T Classic
Re: 426 crate hemi swap into a 1967 b-body coronet [Re: chargervert] #2473140
03/28/18 02:44 AM
03/28/18 02:44 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
You can reuse your existing 23 spline trans and clutch, just need a 8 bolt flywheel.
If you are using the large bell housing a special starter will be required.
Re: 426 crate hemi swap into a 1967 b-body coronet [Re: orange elephants] #2473162
03/28/18 03:11 AM
03/28/18 03:11 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
FWIW, if you don't have a trans. , or are thinking about changing it, something with overdrive will be very beneficial.
Re: 426 crate hemi swap into a 1967 b-body coronet [Re: chargervert] #2473329
03/28/18 02:45 PM
03/28/18 02:45 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Yep, I did the Schumacher Hemi mounts to 440 K-Frame conversion into my 70' Charger & everything was bolt in. Only had to ding my #1 Header tube to clear the power steering line & fitting.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
