Small block 650DP jet Recommendation
#2473165
03/28/18 03:34 AM
03/28/18 03:34 AM
Posts: 1,390 CA.
RAY1969CARS
CA.
Hi guys what I have is the following 72 360 stock bottom end J heads port matched 2.02 and decked .030 Doug 1 5/8 headers Comp cam ex268h Weiand Stealth I 8022 1/2 spacer And 100 shot of nos at the track What size jets do you recommend on my Holley 650 dp
Thanks guys Mopar or no car
Re: Small block 650DP jet Recommendation
[Re: RAY1969CARS]
#2474108
03/29/18 11:10 PM
03/29/18 11:10 PM
Posts: 957 Chicago
PurpleBeeper
Chicago
I'm with Cab & Mattax. Start with stock jetting & adjust if necessary based on track data. The nitrous will be "naturally rich" by a little bit if you use the recommended set of "pills", so in most cases you don't need to increase jet size for the nitrous....maybe when you "fine tune" the car after dozens of track runs.
I suggest you never go over a 100-shot & are probably pushing the limits of cast pistons. If you have a way to adjust timing electronically, maybe pull out 2-degrees or so when the nitrous is on. A little retarded is safe & a little advanced or lean can blow a motor. Also, make SURE your fuel pump can supply the maximum fuel demands of BOTH the engine and the nitrous system (I melted a motor that way before). Lastly, run a little better gas than you need. If the car runs good on 89, put in 93 for the bottle. If it needs 93, then run 100-octane...just as a safety precaution. "Ping" on nitrous can break rings.
70 Roadrunner convt. street car
440+6, NOS, 4-spd, SS springs
'96 Mustang GT convt. street car
'04 4.6 SOHC, NOS, auto, lowered
"Officer, that button is for short on-ramps"
[Re: PurpleBeeper]
#2475005
03/31/18 07:18 PM
03/31/18 07:18 PM
Posts: 1,390 CA.
RAY1969CARS
CA.
