race trlr mod tips,upgrades #247296
03/08/09 08:56 PM
03/08/09 08:56 PM
ELYRIA,OH
blownzoom440 Offline OP
ELYRIA,OH
to start i want to get some electric in mine.[on a budget!could i put a remot box inside with a gromit in the floor and a short plug out the bottom? i can wall mount it.
thanks for any help,ideas!
Re: race trlr mod tips,upgrades [Re: blownzoom440] #247297
03/08/09 09:16 PM
03/08/09 09:16 PM
MR_P_BODY Offline
MR_P_BODY  Offline
On my trailer I have a outside box with a male plug
(the box has the flip close cover) then it goes to a
4 circuit breaker box then to the lights and wall
receptacles. 1 circuit is for the air conditioning
unit in the LQ... very simple set up. If I have power
at the track or home I just plug into the outlet,
if I need the generator(mounted in my truck) I pull
the 1 plug and plug in my gen
EDIT
I have it so the 110 comes from the outside box through
conduit then up through the floor to the breaker box.
I run the conduit so the animals dont eat the wiring
when its setting. Also I have to have a extension
cord for the track(I normally carry 2 heavy duty ones
Re: race trlr mod tips,upgrades [Re: blownzoom440] #247298
03/08/09 09:18 PM
03/08/09 09:18 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
Mine does not have a built in generator door,but it has a land line similar to what a Motorhome has.
It stores away in a small compartment built into the bottom/side at the front.Maybe you could run yours through the front and store it in a box on the tounge somehow?
Just a thought.When you get enough time and money,add a few lights,mine is lit up tons better than my shop(for now).
Re: race trlr mod tips,upgrades [Re: MR_P_BODY] #247299
03/08/09 09:26 PM
03/08/09 09:26 PM
ELYRIA,OH
ELYRIA,OH
i only want 4 110v lines maybe.for now i just need 2 110 outlets for lights and a heater maybe.
Re: race trlr mod tips,upgrades [Re: blownzoom440] #247300
03/08/09 09:37 PM
03/08/09 09:37 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I would still put in 2 circuits . I dont think you
can do it much simpler than what I have, but I run
a fair amount of stuff(if I want, in the LQ), I got
all of the stuff at Home Depot
1 out side receptacle box, male plug for the box
1 4 circuit breaker box with breakers
some wall receptacles and a box of romax and 2 sticks
of conduit with a coupler
EDIT
Heres a pic of my cargo area, my breaker box is in
the bottom of the cabinet
Re: race trlr mod tips,upgrades [Re: blownzoom440] #247301
03/08/09 09:39 PM
03/08/09 09:39 PM
Northern Indiana
Northern Indiana
Mine has two circuits,one for lights and one for outlets.One thing it does not have is an outside weatherproof outlet like some do,could be a nice option,insted of running cords out the door?
Re: race trlr mod tips,upgrades [Re: MR_P_BODY] #247302
03/08/09 09:43 PM
03/08/09 09:43 PM
ELYRIA,OH
ELYRIA,OH
that sounds doable in the long run.i will shop around[homedepot! ]the electrician at work can help in some ways.[tech support.]
i have a lot going on with moving my daughter,grandkids from florida to ohio.
Re: race trlr mod tips,upgrades [Re: blownzoom440] #247303
03/09/09 04:31 AM
03/09/09 04:31 AM
ELYRIA,OH
ELYRIA,OH
i have some other ideas ti run past any1.
i want to help the floor stay in good sgaop so i was thinking of running some aluminum strips in the tire path and where the tire will sit when strapped in.i have 5sq ft of diamond plate aluminum i can cut to size for under the tires.
thanks for your help.
