Scale for Chassis Set-up #2471851
03/25/18 03:59 PM
03/25/18 03:59 PM
The Great State of PA
tabletop390 Offline OP
What scales are you guys using for your set-up? Was probably just going with the Proforms, but wasn't too crazy about some of the reviews with the scale not being able to zero correctly.
Re: Scale for Chassis Set-up [Re: tabletop390] #2471858
03/25/18 04:14 PM
03/25/18 04:14 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Rebel brand. I borrow them from my round round buddy
Re: Scale for Chassis Set-up [Re: tabletop390] #2471862
03/25/18 04:18 PM
03/25/18 04:18 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Been using my Longacres for many years. Circuit board had an issue after a long time. Their customer service on an obsolete item was great. Would buy from them again. I would assume Intercomps are also good but I have no experience with them. I wouldn't buy Chinese crap.
Re: Scale for Chassis Set-up [Re: CMcAllister] #2471888
03/25/18 04:59 PM
03/25/18 04:59 PM
MR_P_BODY Offline
MR_P_BODY  Offline
After years of borrowing a set from work I
bought a set of used Longacres
wave
Re: Scale for Chassis Set-up [Re: MR_P_BODY] #2471901
03/25/18 05:22 PM
03/25/18 05:22 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Never owned or used a set but wouldn't mind buying a set if I wasn't so damn old.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Scale for Chassis Set-up [Re: tabletop390] #2471903
03/25/18 05:27 PM
03/25/18 05:27 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I have Longacres as well and never an issue
Re: Scale for Chassis Set-up [Re: tabletop390] #2471909
03/25/18 05:44 PM
03/25/18 05:44 PM
I use two old 1000 lbs. certified commercial ware house platform scales on wheels, I use them with two home made wooden platforms the same height as the scale plates so I can weigh the front or rear wheels or left and right side at the same time all at the same time, I wish I had four of those scales shruggy
They are large and take up a lot of room in the shop so having a new type race car set up would be a lot easier to store and use twocents
I got both of them from work for free when the ware house bought newer easier to use ones boogie grin
Re: Scale for Chassis Set-up [Re: tabletop390] #2471935
03/25/18 06:38 PM
03/25/18 06:38 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Re: Scale for Chassis Set-up [Re: tabletop390] #2471980
03/25/18 09:04 PM
03/25/18 09:04 PM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
My buddies and I have a old set of Longacre wired scales. Trouble free
"Just a Bracket car dressed up like a streetcar"
Re: Scale for Chassis Set-up [Re: tabletop390] #2472164
03/26/18 08:17 AM
03/26/18 08:17 AM
Ringtown, Pa.
Dartsport540 Offline
Ringtown, Pa.
I have a set of Longacre also. Works Great! Where are you located in Pa. ??
548 cu. in., Bill Mitchell Aluminum Block, CRT 727 auto trans, Alston Chassis. 8.981et at 149.46 mph. 1.204et - 60 foot, So Far....
Re: Scale for Chassis Set-up [Re: tabletop390] #2472174
03/26/18 09:02 AM
03/26/18 09:02 AM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Intercomps here. Had to repair the head once from battery leakage. They're at least 15 years old.
Re: Scale for Chassis Set-up [Re: tabletop390] #2472228
03/26/18 11:48 AM
03/26/18 11:48 AM
Minnesota, USA
humpty Offline
humpty  Offline
Minnesota, USA
I have a set of Longacres I bought used and they work great. Excellent customer service too.
Intercomp is local to me so I’ve been to their facility. Very helpful people and top notch products.
Re: Scale for Chassis Set-up [Re: tabletop390] #2472288
03/26/18 02:09 PM
03/26/18 02:09 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
They are a great tool. Everyone should do it at least once to their car if you don't have access to them or have your own. Every single car we have scaled for the first time makes it best pass first time out on it's next pass.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Scale for Chassis Set-up [Re: 6PKRTSE] #2472305
03/26/18 02:29 PM
03/26/18 02:29 PM
Do you mind sharing what you do to get these results, PLEASE bow grin work
Re: Scale for Chassis Set-up [Re: tabletop390] #2472400
03/26/18 05:53 PM
03/26/18 05:53 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
I got the Proform 67647 Wireless Vehicle Scale Kit in 2016, and am pleased, especially for the price. I really like the wireless feature, as I have used wired scales before, and wireless is way easier. They are plastic, which seems a little flimsy, but they do the job. I had an issue with zeroing and repeatablility, but replacing the batteries solved it. It suppose you can't expect them to work right if the batteries are weak.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Scale for Chassis Set-up [Re: tabletop390] #2472450
03/26/18 07:26 PM
03/26/18 07:26 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Been awhile and wish I could remember the exact dimensions but a race car fabricator friend made his up with wheel cylinders and a 2000 lb pressure guage. Had a 1 ft square curved plate the tire rested on and would press down on the cylinder, Just sit the car on plates and read the guage. He said he had maybe $30 in all four.
He was a big dirt track guy from Indiana and used them from the 50s till he died.
Re: Scale for Chassis Set-up [Re: tabletop390] #2472584
03/27/18 01:10 AM
03/27/18 01:10 AM
ky
68roadrunner Offline
ky
intercomps, only a couple years old. wanted the wireless but couldnt justify the price. like them
Re: Scale for Chassis Set-up [Re: tabletop390] #2472622
03/27/18 04:07 AM
03/27/18 04:07 AM
MD
HEMI472 Online content
HEMI472  Online Content
MD
Do you mind sharing what you do to get these results, PLEASE ................ I would like to know too???? why do you need scales ??
Re: Scale for Chassis Set-up [Re: tabletop390] #2472641
03/27/18 08:17 AM
03/27/18 08:17 AM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Above question.
I’m not answering for him, but I’ve had the same results. Usually when someone seeks me out for scales, they are having some sort of issue.
I’m not just weighing their car, I’m decoding the chassis. Weight = traction. If there is say, 250lbs more weight on one rear tire than the other, the car will want to turn or slide sideways with some tire slip. Scales tell you where to look for problems, and confirm fixes for them.
After using them you can predict how the car wil act when selecting I/C locations, or solve most issues causing the car to do something other than going straight. Even braking issues can be solved on the scales...
Re: Scale for Chassis Set-up [Re: tabletop390] #2472699
03/27/18 12:14 PM
03/27/18 12:14 PM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
Wireless intercomps here.
Whatever brand/style you choose either make, or buy levelers for them. The slightest amount of out of level of the floor causes big differences in weight values. The more ridged the chassis the more pronounced the difference. Weigh your car, then slide a piece of thin cardboard under one scale and watch what happens to the readings. Intercomp makes a set of adjustable pads that you can use to square, and level the pads with. Lock them down and mark the spots on the floor. They also get the car a few inches higher, so reaching the anti roll, or making changes you want on the ground are easier.
