Re: Scale for Chassis Set-up
[Re: tabletop390]
#2471862
03/25/18 04:18 PM
03/25/18 04:18 PM
Posts: 11,530 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Been using my Longacres for many years. Circuit board had an issue after a long time. Their customer service on an obsolete item was great. Would buy from them again. I would assume Intercomps are also good but I have no experience with them. I wouldn't buy Chinese crap.
[Re: MR_P_BODY]
#2471901
03/25/18 05:22 PM
03/25/18 05:22 PM
Posts: 20,160 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Never owned or used a set but wouldn't mind buying a set if I wasn't so damn old.
[Re: tabletop390]
#2471903
03/25/18 05:27 PM
03/25/18 05:27 PM
Posts: 19,361 Las Vegas
Al_Alguire
Las Vegas
I have Longacres as well and never an issue
[Re: tabletop390]
#2471909
03/25/18 05:44 PM
03/25/18 05:44 PM
Posts: 43,127 Bend,OR USA
Cab_Burge
I use two old 1000 lbs. certified commercial ware house platform scales on wheels, I use them with two home made wooden platforms the same height as the scale plates so I can weigh the front or rear wheels or left and right side at the same time all at the same time, I wish I had four of those scales They are large and take up a lot of room in the shop so having a new type race car set up would be a lot easier to store and use I got both of them from work for free when the ware house bought newer easier to use ones
[Re: tabletop390]
#2471980
03/25/18 09:04 PM
03/25/18 09:04 PM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
My buddies and I have a old set of Longacre wired scales. Trouble free
"Just a Bracket car dressed up like a streetcar"
[Re: tabletop390]
#2472164
03/26/18 08:17 AM
03/26/18 08:17 AM
Posts: 1,646 Ringtown, Pa.
Dartsport540
Ringtown, Pa.
I have a set of Longacre also. Works Great! Where are you located in Pa. ??
548 cu. in., Bill Mitchell Aluminum Block, CRT 727 auto trans, Alston Chassis. 8.981et at 149.46 mph. 1.204et - 60 foot, So Far....
[Re: tabletop390]
#2472174
03/26/18 09:02 AM
03/26/18 09:02 AM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
Intercomps here. Had to repair the head once from battery leakage. They're at least 15 years old.
[Re: tabletop390]
#2472288
03/26/18 02:09 PM
03/26/18 02:09 PM
Posts: 4,563 Motor City
6PKRTSE
Motor City
They are a great tool. Everyone should do it at least once to their car if you don't have access to them or have your own. Every single car we have scaled for the first time makes it best pass first time out on it's next pass.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: tabletop390]
#2472400
03/26/18 05:53 PM
03/26/18 05:53 PM
Posts: 7,477 Minnesota
Hemi_Joel
Minnesota
I got the Proform 67647 Wireless Vehicle Scale Kit in 2016, and am pleased, especially for the price. I really like the wireless feature, as I have used wired scales before, and wireless is way easier. They are plastic, which seems a little flimsy, but they do the job. I had an issue with zeroing and repeatablility, but replacing the batteries solved it. It suppose you can't expect them to work right if the batteries are weak.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: tabletop390]
#2472622
03/27/18 04:07 AM
03/27/18 04:07 AM
Posts: 781 MD
HEMI472
MD
Do you mind sharing what you do to get these results, PLEASE ................ I would like to know too???? why do you need scales ??
[Re: tabletop390]
#2472641
03/27/18 08:17 AM
03/27/18 08:17 AM
TRENDZ
Milwaukee WI
Above question.
I’m not answering for him, but I’ve had the same results. Usually when someone seeks me out for scales, they are having some sort of issue. I’m not just weighing their car, I’m decoding the chassis. Weight = traction. If there is say, 250lbs more weight on one rear tire than the other, the car will want to turn or slide sideways with some tire slip. Scales tell you where to look for problems, and confirm fixes for them. After using them you can predict how the car wil act when selecting I/C locations, or solve most issues causing the car to do something other than going straight. Even braking issues can be solved on the scales...
