Re: 426 Hemi Rocker stands, Original or Aluminum?
[Re: Suregrip391]
#2471917
03/25/18 05:57 PM
03/25/18 05:57 PM
Posts: 43,126 Bend,OR USA
Cab_Burge
The OEM cast steel or ductile iron stands are a lot stronger than any of the after market aluminum stands currently out there for stock heads Street and strip motors will live forever with the stock stands I have 5 or 6 broken(cracked) aluminum race stands that are collecting dust, I've never seen any stock cast stands broken from normal use, not on a blown fuel motor that hydraulic, in other words
[Re: Suregrip391]
#2471940
03/25/18 06:58 PM
03/25/18 06:58 PM
Posts: 4,206 New York
polyspheric
New York
X2 - the aluminum stuff is highly stressed, it can't be made thicker to compensate for the reduced stiffness (steel vs. aluminum bending resistance = 3:1).
Boffin Emeritus
[Re: Suregrip391]
#2472204
03/26/18 10:51 AM
03/26/18 10:51 AM
Posts: 13,357 Marion, South Carolina [><]
an8sec70cuda
I have KB aluminum stands on my 572" hemi that have been used since 2006 w/ no trouble at all. 276/284 solid roller, 220 psi seat, 600+ psi open pressure. As heavy as everything is for a hemi, I'd use the aluminum stands as long as they're decent quality parts.
[Re: Suregrip391]
#2472263
03/26/18 01:08 PM
03/26/18 01:08 PM
Posts: 7,477 Minnesota
Hemi_Joel
Minnesota
I'm always looking for ways to make my car lighter. The aluminum stands are an easy and obvious way to do so. So far, I've never had a problem with them.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: an8sec70cuda]
#2472329
03/26/18 03:23 PM
03/26/18 03:23 PM
Posts: 12,587 Great Neck,LI,new york
hemi-itis
I have KB aluminum stands on my 572" hemi that have been used since 2006 w/ no trouble at all. 276/284 solid roller, 220 psi seat, 600+ psi open pressure. As heavy as everything is for a hemi, I'd use the aluminum stands as long as they're decent quality parts. Me too! When i went to aluminum heads & rocker stands the weight saving was close to 90 lbs.With everything else I did the total loss was 200 lbs!
[Re: DoubleD]
#2472389
03/26/18 05:36 PM
03/26/18 05:36 PM
Posts: 4,563 Motor City
6PKRTSE
Motor City
I agree on the Barton's. I am not that concerned with weight. My car is still a street car, no lightweight anyway being all steel, all glass & full interior.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: 6PKRTSE]
#2472431
03/26/18 06:40 PM
03/26/18 06:40 PM
Cab_Burge
[Re: Cab_Burge]
#2473342
03/28/18 03:01 PM
03/28/18 03:01 PM
6PKRTSE
Motor City
Mine Petered out at 7900 on motor on the dyno with my little ole street nitrous cam.
[Re: 6PKRTSE]
#2473670
03/29/18 01:57 AM
03/29/18 01:57 AM
Cab_Burge
Mine Petered out at 7900 on motor on the dyno with my little ole street nitrous cam. How did it peter out, did it quit gaining power or did a part fail? I remember when Don Purdhome (SP?) switch from a stock set of pushrods on his 1968 top Fuel dragster at Orange County testing one night to a set of B&B single tapered pushrods and gained 500 RPM, went from 7000 RPM to 7500 RPM 426 Hemiroid motors and their stinking stock valve train can be a real pain to make work well for higher than 7000 RPM
