Re: 1957 Plynouth Axle Identification - Center Section ID
[Re: 1_WILD_RT]
#425095
07/31/09 10:27 PM
07/31/09 10:27 PM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
Right, Here's the history on the 8.75" that I am already aware of, Quote:
The Chrysler 8-3/4" rear axle assembly was introduced in 1957. 1-3/8" small stem pinion... (aka. '741')... Carrier casting numbers: 1820657 (1957-1964), 2070741 (1964-1972). 1-3/4" large stem pinion... (aka. '742')... Carrier casting numbers: 1634985 (1957-1964), 2070742 (~1961-1969). 1-7/8" tapered stem pinion... (aka. '489')... Carrier casting numbers: 2881488, 2881489 (1969-1974).
Notice there's no mention of my casting number? I think I may have an 8.25" unit, really weird that they'd build such a dead ringer for an 8.75" in a smaller unit.
[Re: ScottSmith_Harms]
#425102
08/01/09 06:20 PM
08/01/09 06:20 PM
Posts: 25,796 Rio Linda, CA
John_Kunkel
Rio Linda, CA
All 8 3/4" axles are 30-spline, in pre-'64 units the axles are different length for Sure-Grip and open differential so, if the original has an open differential and you want to swap in a Sure-Grip, you'll need to trim 1/8" from each axle shaft.
#2471679
03/25/18 09:29 AM
03/25/18 09:29 AM
Posts: 905 SD
zrxkawboy
SD
I don't know specifically about the casting #, but I know that in '57/58, the 6-cyl cars got an 8.25" diff while the V8 cars got the 8.75".
It's Swifty! Swifty, you toad sucker!
