Fun dyno day with an old school 496 #247151
03/08/09 05:27 PM
03/08/09 05:27 PM
Kewaskum, WI
K
Kelob_pie Offline OP
K
Kewaskum, WI
Hi guys, had another date with the dyno yesterday. This was an old school 496 built by MM in 1993. Ultradyne .613, stage II ported 906's, 10 to 1 comp, welded crank, stock rods. I had it in my car then sold it to my buddy, he put a six pack on it and wanted it dyno tuned and wanted to know what power was for kicks. So off to the dyno we went. First 15 pulls were to get jetting dialed in, then another 15 pulls messing around with timing. It liked 35 best which surprised me, I thought it would like 38ish with open chambered heads, but not so. I will also post a couple more dyno sheets of motors that I have built, these were all on the same dyno.
Re: Fun dyno day with an old school 496 [Re: Kelob_pie] #247152
03/08/09 05:35 PM
03/08/09 05:35 PM
Illinois
CRE2004 Offline
super gas
CRE2004  Offline
super gas
Illinois
John, I usually try and date women, not machines. I always knew you were a little funny
Re: Fun dyno day with an old school 496 [Re: CRE2004] #247153
03/08/09 05:59 PM
03/08/09 05:59 PM
Kewaskum, WI
K
K
Kewaskum, WI
Ya, I know, but sometimes machines are more exciting tham women!!!
Re: Fun dyno day with an old school 496 [Re: Kelob_pie] #247154
03/08/09 06:08 PM
03/08/09 06:08 PM
Kewaskum, WI
K
K
Kewaskum, WI
Here is a 451, E-heads, 10.4 to 1 comp, 226 hyd. flat tappet from Scott B., 870 holley, all shelf parts budget easy build no maintenance motor.
Re: Fun dyno day with an old school 496 [Re: Kelob_pie] #247155
03/08/09 06:16 PM
03/08/09 06:16 PM
Kewaskum, WI
K
K
Kewaskum, WI
OK, last one. Here is a no maintenance street 506, E-heads, 240 hyd. flat tappet from Scott B., 10.25 to 1 comp, performer rpm, 850 Demon, pretty much spanked the 496 all the way around especially in torque dept.
Re: Fun dyno day with an old school 496 [Re: Kelob_pie] #247156
03/08/09 09:21 PM
03/08/09 09:21 PM
Central NC
gch Offline
gch  Offline
Central NC
My head hurts from looking sideways.Thanks for the info.I like the numbers on the 506.Pretty impressive for the cam size.
Re: Fun dyno day with an old school 496 [Re: gch] #247157
03/08/09 10:19 PM
03/08/09 10:19 PM
NC
440Jim Offline
440Jim  Offline
NC
That goes to show what a little head flow will do. Or lack of head flow with 496 CID and medium cam/CR.
It wasn't long ago, that was a typical build.
