A-body spindles #247144
03/08/09 05:18 PM
03/08/09 05:18 PM
Mt.Vernon ,Ohio
VernMotor Offline OP
Mt.Vernon ,Ohio
Does anyone know for sure that a 71 spindle will exchange for a 67 spindle ? they look different .But they also look like the ball joints end up in the same place ?
Re: A-body spindles [Re: VernMotor] #247145
03/08/09 05:50 PM
03/08/09 05:50 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Not sure about the A bodies. I have 66 Ply B body drum spindles on the front of my 71.
Re: A-body spindles [Re: VernMotor] #247146
03/08/09 05:58 PM
03/08/09 05:58 PM
I have swapped the 1967 front end and K member out for the later 1973, it all bolted up. I didn't like the 1967 K member due to the single bolt attaching point on the K member for the idler arm I'm sure that the 1967 to 1973 A body drum brake spindles for the two different size brakes are the same for the same size brakes, the disc brake spindles may be different for the Kelsey Hayes four piston calipers versus the later bigger single piston caliper. I believe all of the A body ball joints are the same form 1967 to 1972 regardless of the type and size brakes See if you can access Moogs on line catalog on those parts and see if the part numbers are the same
Re: A-body spindles [Re: Cab_Burge] #247147
03/08/09 06:32 PM
03/08/09 06:32 PM
Mt.Vernon ,Ohio
Mt.Vernon ,Ohio
Yes I am changing the whole deal..K-member-spindles-lower=upper-a-arms--Here is some pics.of them..I think it will all be ok..Just thought I would ask..
here is two of the 67
And here is 3 of the 71
Re: A-body spindles [Re: VernMotor] #247148
03/08/09 06:41 PM
03/08/09 06:41 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
The 67 pitman arm is a one year deal, other than that, i think they're about the same.
As Cab says, the KH spindles are different, i know because i looked into a willwood disc kit and it wouldn't fit my spindles.
Mike
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: A-body spindles [Re: VernMotor] #247149
03/08/09 08:42 PM
03/08/09 08:42 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
The first picture you posted is a 10" drum knuckle. The second picture is a 9" drum knuckle.
The whole assemblies will interchange, but the spindles take different bearings.
Re: A-body spindles [Re: DoctorDiff] #247150
03/08/09 10:05 PM
03/08/09 10:05 PM
Mt.Vernon ,Ohio
Mt.Vernon ,Ohio
Good eye ..your right I just checked ! LOL
67 car was a V8 and the 71 car was a 6cy
