single carb NSS racing deal #2470696
03/22/18 09:38 PM
03/22/18 09:38 PM
Rittman Ohio
fourgearsavoy Offline OP
Rittman Ohio
I want to race in NSS this summer but I really don't have the coin to do it right with an Indy intake or a worked cross ram.
So I am looking at the 11.50 class with a single Edelbrock and I'm not sure a 750 will do the job. I have been looking at the 800 AVS Thunder carb but I can get a 750 Performer for about half the price. Do you think 50 CFM will be that much differn't shruggy
Has anyone ever run this class with a single Carter/Edelbrock style carb?
Gus beer
64 Plymouth Savoy
Dana 60
Re: single carb NSS racing deal [Re: fourgearsavoy] #2470699
03/22/18 09:44 PM
03/22/18 09:44 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
the 750's don't flow near 750, probably a little over 700. 800's probably don't flow 800 but i'd bet around 780. the extra venturi area of the 800 is what i'd be looking for. i'd do the 800; they can be made to work.
Re: single carb NSS racing deal [Re: fourgearsavoy] #2470710
03/22/18 10:19 PM
03/22/18 10:19 PM
central ohio
N
nss guy Offline
nss guy  Offline
N
central ohio
I have seen several racers with single 600 or 750 afb's.
Remember you will be racing on an index, just need to be consistent not the fastest. Heck all the manifold test I've seen show the crossram down 90+ horsepower.
Re: single carb NSS racing deal [Re: fourgearsavoy] #2470715
03/22/18 10:30 PM
03/22/18 10:30 PM
ohio
67mprfan Offline
67mprfan  Offline
ohio
Don't they also allow the use of a single Holley in 1 of the classes
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it.
67 Belvedere that worked it's way in the 10's
Re: single carb NSS racing deal [Re: fourgearsavoy] #2470858
03/23/18 10:15 AM
03/23/18 10:15 AM
Georgia
66coronet Offline
66coronet  Offline
Georgia
I know a single 800 will work. That is what we run on our 67 coronet wagon in NSS. Corky Bumpus on a mopar and Jim Netherland on a buick also run a single 800.
We worked with an avs and the hesitation is hard to get rid of. Not a bog but a slight hesitation. I would go with an old style 800 performer series carb.It will work with some tuning.
Something else worth looking into. There is a new edelbrock carb. It has annular boosters to help it during the transition. I have not looked at the sizes available but its worth looking into.
Re: single carb NSS racing deal [Re: fourgearsavoy] #2470859
03/23/18 10:16 AM
03/23/18 10:16 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Indexes are on a .25 second scale now instead of .50 second. The 750's are pretty inexpensive used. I'd try 750.
Doug
Re: single carb NSS racing deal [Re: fourgearsavoy] #2470908
03/23/18 12:44 PM
03/23/18 12:44 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
I got rid of the 800avs hesitation by getting rid of .113" primary jets and going to a smaller squirter. playing with step-up springs can help.
Re: single carb NSS racing deal [Re: 67mprfan] #2470965
03/23/18 02:42 PM
03/23/18 02:42 PM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
I believe only the NMCA nostalgia super stock classes allows single carb combos. Victory and NSS Inc. only allow dual carbs. Not sure about the other groups. The Modman from Indy seems to work OK, a lot of guys used to run the older edelbrock 2x4 manifolds. And as mentioned you pick an index, so if its a few tenths off, no big deal. I ran a 63 factory cross ram for several years, it was 4 tenths slower than a edelbrock victor Jr , I modified to run 2 carbs. Rules state you must run a as cast manifold but are allowed to modify the top. I have access to a spool gun to weld alumninum, I got $350 in my intake and two used 750 federal mogul AFB carbs off ebay for $75 each, car has run a best of 9.65 @ 140mph. The best I got the cross ram to run was 10.01 & 138mph, same engine only manifold change, the same carbs on both manifolds.
Re: single carb NSS racing deal [Re: jwb123] #2470982
03/23/18 03:19 PM
03/23/18 03:19 PM
NE Ohio
DoubleD Online content
DoubleD  Online Content
NE Ohio
Run the AFB's a 750 will work good - 800 is little better up top but lots of 750's out there for sale - there are a few tricks you can apply to them to make them work better and be real consistent - but they are easy to tune - glad to help you out to get you to the D42 race
Re: single carb NSS racing deal [Re: DoubleD] #2471100
03/23/18 08:18 PM
03/23/18 08:18 PM
Rittman Ohio
Rittman Ohio
Thanks a lot guys I think I will get a 750 and tune it from there. I have an AFR meter that I'm putting on the car this year too so that should at least tell me where the tune is.
The car has run 10.91 with a big Holley so it will probably slow down some with a 750 but maybe not shruggy I might be overcarbed.
So I'll be looking for a Performer 750 that hasn't been touched yet so I have a good base to start tuning with.
Being a stick car I don't think I will have a bog issue because I leave on the 2-step at 4500 with the pedal on the wood.
Gus beer
64 Plymouth Savoy
Dana 60
Re: single carb NSS racing deal [Re: fourgearsavoy] #2471116
03/23/18 08:48 PM
03/23/18 08:48 PM
central ohio
N
nss guy Offline
nss guy  Offline
N
central ohio
Originally Posted By fourgearsavoy
Thanks a lot guys
Gus beer
Sounds like fun!!
Re: single carb NSS racing deal [Re: nss guy] #2471153
03/23/18 10:42 PM
03/23/18 10:42 PM
Rittman Ohio
Rittman Ohio
Thanks a lot guys
Gus beer
Sounds like fun!!
Yeah let the clutch fly and start rowin gears fast because I'm sure you know how fast these 493 Indy head engines rev.
Well I got a line on a few carbs already thumbs One is an older Competition Series Carter AFB and he also has a few Eddy carbs but not sure which ones.
So I'll pick up a 12 pack and go check them out tomorrow laugh2
Gus beer
64 Plymouth Savoy
Dana 60
Re: single carb NSS racing deal [Re: fourgearsavoy] #2471251
03/24/18 10:06 AM
03/24/18 10:06 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Lots of guys that run trans brakes and sticks with AFB's run with the rear air door wedged open. It's easy to try with a couple of pieces of 1/4" vacuum line stuffed into the upper corners of the rear casting above the door weights. Doesn't work well with foot brake or low RPM full throttle leave.
Doug
Re: single carb NSS racing deal [Re: dvw] #2471437
03/24/18 06:32 PM
03/24/18 06:32 PM
Rittman Ohio
Rittman Ohio
Thanks Doug I was wondering how that door reacts when on the rev limiter for a second. Will it flutter on the 2-step and not work correctly shruggy Maybe someone filmed it with a Go-pro to see what happens.
I'm looking forward to testing as soon as the snow melts around here.
Gus beer
64 Plymouth Savoy
Dana 60
Re: single carb NSS racing deal [Re: fourgearsavoy] #2471447
03/24/18 06:44 PM
03/24/18 06:44 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
A mate with a cross ram 409 chev stroker took the air door and weights out completely . Drives it on street a bit said no issues
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: single carb NSS racing deal [Re: fourgearsavoy] #2471550
03/24/18 09:40 PM
03/24/18 09:40 PM
Aus
hysteric Offline
hysteric  Offline
Aus
Pick the one with the longest Booster. If there is one.
A Genuine Carter 750 will have a longer booster than Later Federal Mogul or Edelbrock Carbs which places the Booster in the correct position of being at the Vena Contractor.
The later carbs got the Booster from the 625 series carbs which has the Vena Contractor mush higher.
Here are the 2 different lengths:
[img]https://photos.google.com/share/AF1QipP8...nR2cGFpRFIwMkFR[/img]
I have also installed holley air bleeds in the top of mine to make it more tunable.
Hysteric
Re: single carb NSS racing deal [Re: fourgearsavoy] #2471590
03/24/18 11:17 PM
03/24/18 11:17 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
It seems to me back in the late 60's we tightened the spring on the secondary door to get more fuel less air on the hit ? heck that's 50 years ago. Never heard of anyone back then taking it out. Maybe that was stone age thinking. If it wasn't in Hot Rod Magazine we didn't know jack schit.
Brain just had a recall that was AVS carb , 1968 model, Didn't think a AFB had a secondary door.
Re: single carb NSS racing deal [Re: jwb123] #2471605
03/24/18 11:52 PM
03/24/18 11:52 PM
PA
Scully Offline
Scully  Offline
PA
What RPM were you going through the traps at with the cross ram.
Re: single carb NSS racing deal [Re: fourgearsavoy] #2476487
04/02/18 10:10 PM
04/02/18 10:10 PM
Richmond, Tx. (Houston)
GTSDave Offline
GTSDave  Offline
I am running an old heavily modified STR15 with a pair of Diamondback Engines modified 800 Eddies.
I launch at 5700 and shift at 7600 (Jerico.) Best 1/8th so far was a 6.13 with this combo.
-Dave
PLEASE Pray for our brothers and sisters in harms way.
If you are the owner of a GTS us at the GTS Registry www.gtsregistry.com
Re: single carb NSS racing deal [Re: fourgearsavoy] #2476543
04/02/18 11:50 PM
04/02/18 11:50 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Gus I think you should hunt for an 800, you are definitely not over carbed right now. I sent you a text.
