single carb NSS racing deal
#2470696
03/22/18 09:38 PM
03/22/18 09:38 PM
Posts: 10,552 Rittman Ohio
fourgearsavoy
Rittman Ohio
I want to race in NSS this summer but I really don't have the coin to do it right with an Indy intake or a worked cross ram. So I am looking at the 11.50 class with a single Edelbrock and I'm not sure a 750 will do the job. I have been looking at the 800 AVS Thunder carb but I can get a 750 Performer for about half the price. Do you think 50 CFM will be that much differn't Has anyone ever run this class with a single Carter/Edelbrock style carb? Thanks Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
Re: single carb NSS racing deal
[Re: fourgearsavoy]
#2470715
03/22/18 10:30 PM
03/22/18 10:30 PM
Posts: 1,030 ohio
67mprfan
ohio
Don't they also allow the use of a single Holley in 1 of the classes
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it. 67 Belvedere that worked it's way in the 10's
[Re: DoubleD]
#2471100
03/23/18 08:18 PM
03/23/18 08:18 PM
fourgearsavoy
Rittman Ohio
Thanks a lot guys I think I will get a 750 and tune it from there. I have an AFR meter that I'm putting on the car this year too so that should at least tell me where the tune is. The car has run 10.91 with a big Holley so it will probably slow down some with a 750 but maybe not I might be overcarbed. So I'll be looking for a Performer 750 that hasn't been touched yet so I have a good base to start tuning with. Being a stick car I don't think I will have a bog issue because I leave on the 2-step at 4500 with the pedal on the wood. Gus
[Re: fourgearsavoy]
#2471116
03/23/18 08:48 PM
03/23/18 08:48 PM
Posts: 1,442 central ohio
nss guy
central ohio
Thanks a lot guys Being a stick car I don't think I will have a bog issue because I leave on the 2-step at 4500 with the pedal on the wood. Gus Sounds like fun!!
[Re: nss guy]
#2471153
03/23/18 10:42 PM
03/23/18 10:42 PM
fourgearsavoy
Rittman Ohio
Thanks a lot guys Being a stick car I don't think I will have a bog issue because I leave on the 2-step at 4500 with the pedal on the wood. Gus Sounds like fun!! Yeah let the clutch fly and start rowin gears fast because I'm sure you know how fast these 493 Indy head engines rev. Well I got a line on a few carbs already One is an older Competition Series Carter AFB and he also has a few Eddy carbs but not sure which ones. So I'll pick up a 12 pack and go check them out tomorrow Gus
[Re: dvw]
#2471437
03/24/18 06:32 PM
03/24/18 06:32 PM
fourgearsavoy
Rittman Ohio
Thanks Doug I was wondering how that door reacts when on the rev limiter for a second. Will it flutter on the 2-step and not work correctly Maybe someone filmed it with a Go-pro to see what happens. I'm looking forward to testing as soon as the snow melts around here. Gus
[Re: fourgearsavoy]
#2471447
03/24/18 06:44 PM
03/24/18 06:44 PM
Posts: 2,458 Sydney,Australia
tex013
Sydney,Australia
A mate with a cross ram 409 chev stroker took the air door and weights out completely . Drives it on street a bit said no issues
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: fourgearsavoy]
#2471550
03/24/18 09:40 PM
03/24/18 09:40 PM
Posts: 117 Aus
hysteric
Aus
Pick the one with the longest Booster. If there is one. A Genuine Carter 750 will have a longer booster than Later Federal Mogul or Edelbrock Carbs which places the Booster in the correct position of being at the Vena Contractor. The later carbs got the Booster from the 625 series carbs which has the Vena Contractor mush higher. Here are the 2 different lengths: [img] https://photos.google.com/share/AF1QipP8...nR2cGFpRFIwMkFR[/img] I have also installed holley air bleeds in the top of mine to make it more tunable. Hysteric
[Re: fourgearsavoy]
#2471590
03/24/18 11:17 PM
03/24/18 11:17 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
It seems to me back in the late 60's we tightened the spring on the secondary door to get more fuel less air on the hit ? heck that's 50 years ago. Never heard of anyone back then taking it out. Maybe that was stone age thinking. If it wasn't in Hot Rod Magazine we didn't know jack schit.
Brain just had a recall that was AVS carb , 1968 model, Didn't think a AFB had a secondary door.
[Re: jwb123]
#2471605
03/24/18 11:52 PM
03/24/18 11:52 PM
Posts: 200 PA
Scully
PA
I believe only the NMCA nostalgia super stock classes allows single carb combos. Victory and NSS Inc. only allow dual carbs. Not sure about the other groups. The Modman from Indy seems to work OK, a lot of guys used to run the older edelbrock 2x4 manifolds. And as mentioned you pick an index, so if its a few tenths off, no big deal. I ran a 63 factory cross ram for several years, it was 4 tenths slower than a edelbrock victor Jr , I modified to run 2 carbs. Rules state you must run a as cast manifold but are allowed to modify the top. I have access to a spool gun to weld alumninum, I got $350 in my intake and two used 750 federal mogul AFB carbs off ebay for $75 each, car has run a best of 9.65 @ 140mph. The best I got the cross ram to run was 10.01 & 138mph, same engine only manifold change, the same carbs on both manifolds. What RPM were you going through the traps at with the cross ram.
[Re: fourgearsavoy]
#2476487
04/02/18 10:10 PM
04/02/18 10:10 PM
Posts: 3,048 Richmond, Tx. (Houston)
GTSDave
I am running an old heavily modified STR15 with a pair of Diamondback Engines modified 800 Eddies.
I launch at 5700 and shift at 7600 (Jerico.) Best 1/8th so far was a 6.13 with this combo.
-Dave
PLEASE Pray for our brothers and sisters in harms way. If you are the owner of a GTS us at the GTS Registry www.gtsregistry.com
[Re: fourgearsavoy]
#2476543
04/02/18 11:50 PM
04/02/18 11:50 PM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
Gus I think you should hunt for an 800, you are definitely not over carbed right now. I sent you a text.
