65 torque converter seal?? #2469011
03/20/18 11:24 AM
03/20/18 11:24 AM
British Columbia
Y
yellowgtx Offline OP
Y
British Columbia
Is the torque converter seal and the filter kit the same for the 65 727 Push Button tranny as for the 66 and up seal and kit.
Re: 65 torque converter seal?? [Re: yellowgtx] #2469166
03/20/18 03:13 PM
03/20/18 03:13 PM
What do the parts book show? Mopar change the converter, pump and gears in the pump in 1967 and up work
They also did away with the rear pump when they switch the shifting linkage to external away from the cables in 1966 shruggy
Call one of the better Hi Po tranny and converter company and ask them if the 1962 to 1966 converter interchange and order the seal from them up twocents scope
Re: 65 torque converter seal?? [Re: yellowgtx] #2469168
03/20/18 03:21 PM
03/20/18 03:21 PM
Minn
SportF Offline
SportF  Offline
Minn
IF you are talking front pump seal, they are the same 62 up.
I think the 65 has a rear pump (can you push start a 65?) IF so, you should install a 62-65 filter. This early filter has an extra hole for oil pickup for rear pump.
Best of luck.
Re: 65 torque converter seal?? [Re: SportF] #2469178
03/20/18 03:32 PM
03/20/18 03:32 PM
Northern MN
1E2C Offline
1E2C  Offline
Northern MN
Best of luck.
Yes, there are instructions for push starting a 65 in the owner's manual.
Re: 65 torque converter seal?? [Re: yellowgtx] #2469219
03/20/18 04:42 PM
03/20/18 04:42 PM
A727Tflite Online content
A727Tflite  Online Content
SportF nailed it. 100% correct. You don't want to use the one hole filter on a valve body made for the two hole/rear pump style application.
Seals remain dimensionally the same from 1962 - 2008 for all 727/46/47/48 transmissions.
The later style has helical lips in the ID that helps "pump" fluid in to the trans to prevent leakage.
Re: 65 torque converter seal?? [Re: yellowgtx] #2469349
03/20/18 08:17 PM
03/20/18 08:17 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Many of the single hole filters currently available still have the extra hole in the internal metal frame. Probe with your finger tip and, if the hole is there, trim away the fabric with an X-acto knife to expose the second hole.
This gives the benefit of using the later filters with an increased filter area on the early trans. Won't work on the very early pans with a drain plug.
Re: 65 torque converter seal?? [Re: yellowgtx] #2470540
03/22/18 06:21 PM
03/22/18 06:21 PM
British Columbia
Y
Y
British Columbia
Thanks for all the replies.. I forgot about the rear pump on pre 66 tranys. I would of just got a 727 filter kit and not had the 2nd hole. Basically That is why I checked before I ordered one from NAPA. Most places show same one from 62 up in there parts books.
After almost 71 years I am on my last car. A 65 Plymouth Satellite straight axle altered wheel base car.
Re: 65 torque converter seal?? [Re: John_Kunkel] #2470777
03/23/18 12:52 AM
03/23/18 12:52 AM
John you're the man! (as always).
Re: 65 torque converter seal?? [Re: John_Kunkel] #2470946
03/23/18 02:01 PM
03/23/18 02:01 PM
moparx Offline
moparx  Offline
john, thanks for the pic comparing the two filters and having the second hole needed for the rear pump in the later filters. i never would have thought of looking for that. up thanks again !
beer
Re: 65 torque converter seal?? [Re: moparx] #2470995
03/23/18 03:41 PM
03/23/18 03:41 PM
South Bend
John Brown Offline
John Brown  Offline
South Bend
I remember changing the fluid and filter on my hundred dollar 65 Chrysler Newport, but it had a column shift. Does that mean either filter would have worked equally well on it?
Re: 65 torque converter seal?? [Re: John_Kunkel] #2471766
03/25/18 01:16 PM
03/25/18 01:16 PM
British Columbia
Y
Y
British Columbia
Thanks for the pictures John. I also solved the pump seal size question. just pulled the old one out and got the number off it. Great info Guys as always.
