Stage V hemi rockers #2470728
03/22/18 11:11 PM
03/22/18 11:11 PM
Temperance, MI
68 HEMI GTS Offline OP
Temperance, MI
Currently upgrading my engine, probably going with stage v rockers. Any con's I should know about. The price gap between these and Barton's are pretty minimal but the Barton's look like they could be a headache. Thinking I would need lifter bushings to restrict the oil to the top end if I went with push rod oiling ( on the Barton's). Not to mention I'll need new lifters also if I went the Barton route.
68 Dart GTS "HEMI" 10.30 @ 131 pump gas street car 3780#
69 Roadrunner 511 six pack 10.92 drive to track street car
Re: Stage V hemi rockers [Re: 68 HEMI GTS] #2470764
03/23/18 12:23 AM
03/23/18 12:23 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
You can restrict the pushrods to limit how much oil goes upstairs.I still have shaft oiling but sent oil up the ex pr's and lost 15 psi.Restricted the 15 psi came right back!
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Stage V hemi rockers [Re: hemi-itis] #2470843
03/23/18 08:55 AM
03/23/18 08:55 AM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
The last set of T&D (Barton) rockers I worked with had built in spray bar oiling. You drill and tap a 1/8" x3 an fitting in the oil galley and run a line to the bedplate to oil them. They are a much nicer set up than traditional Hemi rocker gear. So easy to put one rocker at a time on.
Re: Stage V hemi rockers [Re: fbs63] #2470846
03/23/18 09:24 AM
03/23/18 09:24 AM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
The Barton valve train is the Only way to go
Re: Stage V hemi rockers [Re: 68 HEMI GTS] #2470876
03/23/18 11:07 AM
03/23/18 11:07 AM
Stuttgart, Arkansas
rickseeman Online content
rickseeman  Online Content
Stuttgart, Arkansas
Barton makes great stuff but the Stage V is as simple as a stone and you will love it.
2011 Drag Pak Challenger
Re: Stage V hemi rockers [Re: DoubleD] #2470884
03/23/18 11:27 AM
03/23/18 11:27 AM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I agree. I have Barton's on my 528". Spray bar is visible.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Stage V hemi rockers [Re: 68 HEMI GTS] #2471132
03/23/18 09:40 PM
03/23/18 09:40 PM
Superfreak
Superfreak
I was surprised how heavy the Barton assembly was.
Re: Stage V hemi rockers [Re: 68 HEMI GTS] #2471201
03/24/18 01:11 AM
03/24/18 01:11 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
I think mine was about 17 pounds x 2 but the ease of assembly and one rocker removal if needed is the big plus.
