Best way to restore a cross ram magnesium intake #2470456
03/22/18 04:05 PM
03/22/18 04:05 PM
cheshire, ct
davesmopars Offline OP
cheshire, ct
I will try here first, not really sure where to post this.
Thanks for any help
Keeper of the 440 M code Cuda registry
mcodecuda@yahoo.com
Re: Best way to restore a cross ram magnesium intake [Re: davesmopars] #2470541
03/22/18 06:21 PM
03/22/18 06:21 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Be more specific, what's wrong with it?
Re: Best way to restore a cross ram magnesium intake [Re: Stanton] #2470570
03/22/18 07:01 PM
03/22/18 07:01 PM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
All that i ever did with mine was to put it in the bead cleaning cabinet, and went and did it's thing on it.
Haven't got a clue as to the type of grit that was in the cabinet at that time.
Whoever had the cabinet, where i worked at the time.
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: Best way to restore a cross ram magnesium intake [Re: davesmopars] #2470661
03/22/18 08:38 PM
03/22/18 08:38 PM
Those manifolds are corroding all the time, even after having them cleaned up, unless you have them Dow Coated to prevent further corrosion work
I installed one last year on a early 1966 street Hemi motor in a 1963 Dodge Polara 440 hardtop for a friend and his Son, it was brand new and part of it was corroded black and part was dark gun metal grey from corrosion shruggy
I had a old 426 Hemi Cragar magnesium blower manifold cleaned and Dow coated by Mert Littlefield blower company a long time ago, it looks exactly the same now as it did when we had it done is what my customer is saying work
I had a old set of Motor Wheel Magnesium rear rims, what a pain to keep up down
Re: Best way to restore a cross ram magnesium intake [Re: Cab_Burge] #2470680
03/22/18 09:13 PM
03/22/18 09:13 PM
South Bend
John Brown Offline
John Brown  Offline
South Bend
Gibbs oil, according to the street rod freaks on the H.A.M.B. Don't believe much they have to say, but I have friends that use it and swear by it.
Re: Best way to restore a cross ram magnesium intake [Re: davesmopars] #2470796
03/23/18 01:50 AM
03/23/18 01:50 AM
cheshire, ct
cheshire, ct
Restoring a BO29 Car.
Its an original 68 BO29 intake, its nasty looking. I did not know it I could bead blast it. If so what grit? and if I can, what do I do to keep nice?
thanks
mcodecuda@yahoo.com
Re: Best way to restore a cross ram magnesium intake [Re: John Brown] #2470817
03/23/18 03:22 AM
03/23/18 03:22 AM
brisbane,australia
coletrickle Offline
coletrickle  Offline
brisbane,australia
GIBBS BRAND LUBRICANT ,Its the best for magnesium,it seems like snake oil when you speak of it.But when it comes to corrosion its the best.NASA do not do an electrical connection with out GIBBS,.It is a must have in the workshop/home.if its 45 bucks here in oz it should be 20 bucks US ,Give it a try.😆
Re: Best way to restore a cross ram magnesium intake [Re: davesmopars] #2470818
03/23/18 03:31 AM
03/23/18 03:31 AM
brisbane,australia
coletrickle Offline
coletrickle  Offline
brisbane,australia
thanks
Once blasted its not the correct finish,I aquired an old supercharged nitro honda cb350 as last raced in 1976,it had a lot of heavyish corrosion etc just been spraying with Gibbs every couple of months for the last year,corrosions all gone rust spots on chrome gone paint is more vibrant and all cracks in rubbers gone and its offically still as found nothing more than some really gentle rubbing on some of the crustiest spots.Pretty much spent $80 and done [censored] all and its finished .
Re: Best way to restore a cross ram magnesium intake [Re: coletrickle] #2470832
03/23/18 05:18 AM
03/23/18 05:18 AM
P
PasiR Offline
PasiR  Offline
P
Soda blasting.
Re: Best way to restore a cross ram magnesium intake [Re: davesmopars] #2470879
03/23/18 11:15 AM
03/23/18 11:15 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
I don't blast if I can keep from it. If you want the natural finish you can remove the paint with stripper (might take many applications). When you have the paint off, spray it with WD-40, it will soak it in. Be sure to spray inside the runners and underneath. Might need to do it once a week for awhile until it stabilizes then it will last a long time. Decades.
2011 Drag Pak Challenger
Re: Best way to restore a cross ram magnesium intake [Re: rickseeman] #2470975
03/23/18 03:00 PM
03/23/18 03:00 PM
dogdays Offline
dogdays  Offline
X 10 on no blasting. It changes the surface forever, or at least until you can have the factory finish redone, which may be never. Maybe baking soda will clean without changing the surface, but glass beading makes it furry.
For a slightly different look, I glass beaded all the aluminum on one engine and then shot it with high temperature clear. Now it's a shiny gray color, but that's what I was after.
Gibbs Lubricant is entirely different from Joe Gibbs Driven motor oil. Here's a link: http://www.gibbsbrandlubricant.com/shop.htm
R.
Let's not forget Boeshield T-9. https://boeshield.com/products/
Re: Best way to restore a cross ram magnesium intake [Re: davesmopars] #2471114
03/23/18 08:37 PM
03/23/18 08:37 PM
cheshire, ct
cheshire, ct
Thanks for the help
mcodecuda@yahoo.com
Re: Best way to restore a cross ram magnesium intake [Re: davesmopars] #2472700
03/27/18 12:20 PM
03/27/18 12:20 PM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
Mag parts look amazing in DOW7 coating.
Re: Best way to restore a cross ram magnesium intake [Re: dthemi] #2472708
03/27/18 12:41 PM
03/27/18 12:41 PM
cheshire, ct
cheshire, ct
Have you used it or know somebody that does this?
thanks
mcodecuda@yahoo.com
Re: Best way to restore a cross ram magnesium intake [Re: davesmopars] #2472743
03/27/18 01:49 PM
03/27/18 01:49 PM
thanks
Try contacting Littefield blowers,714-992-9292, for that scope twocents
Re: Best way to restore a cross ram magnesium intake [Re: davesmopars] #2483768
04/16/18 06:43 PM
04/16/18 06:43 PM
cheshire, ct
cheshire, ct
can I have the machine shop hot tank the intake?
mcodecuda@yahoo.com
Re: Best way to restore a cross ram magnesium intake [Re: davesmopars] #2483803
04/16/18 07:51 PM
04/16/18 07:51 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
can I have the machine shop hot take the intake?
Not if you ever want to see it again !!
Re: Best way to restore a cross ram magnesium intake [Re: Stanton] #2483898
04/16/18 10:15 PM
04/16/18 10:15 PM
cheshire, ct
cheshire, ct
Thanks, thats what I thought.
mcodecuda@yahoo.com
Re: Best way to restore a cross ram magnesium intake [Re: Cab_Burge] #2483903
04/16/18 10:21 PM
04/16/18 10:21 PM
cheshire, ct
cheshire, ct
So I called these guys, talked about the process and then I asked him how to take the paint off and he's said to sand blast it. Everyone says not to. He said 300.00 to polish it and 250.00 to have it coated.
mcodecuda@yahoo.com
Re: Best way to restore a cross ram magnesium intake [Re: davesmopars] #2483957
04/16/18 11:46 PM
04/16/18 11:46 PM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
This website about racing wheels had some info on restoring and caring for bare magnesium.
http://www.roadsters.com/wheels/#Mag
