Vacum pump ? #247030
03/08/09 03:32 PM
03/08/09 03:32 PM
southern conn
1969gtx Offline OP
1969gtx  Offline OP
southern conn
Should I run special rings with a crankcase vacum pump?
Thanks Bill
1965 A/FX Plymouth 9.50 et @139 mph
1965 A/FX awb plymouth flashback [email]10.26@129mph[/email] mph on pump gas 426 hemi
1969 GTX Hemi 4 speed 12.50 et @ 112mph in F.A.S.T TRIM
1970 GTX 4406pac 4 speed 11.05 @126.9 mph in F.A.S.T TRIM
http://www.AFXER.com
Re: Vacum pump ? [Re: 1969gtx] #247031
03/08/09 03:37 PM
03/08/09 03:37 PM
Ohio
3404 Offline
3404  Offline
Ohio
I believe you normally should run a vaccuum pump when you are using low tension piston rings. The pump helps keep the rings sealed to the cylinder walls.
Re: Vacum pump ? [Re: 1969gtx] #247032
03/08/09 06:13 PM
03/08/09 06:13 PM
Thanks Bill
only if you want to optimised the set up
