painting brackets and pulley's #246989
03/08/09 01:57 PM
03/08/09 01:57 PM
California
70SportSatellite Offline OP
super street
super street
California
i've done a search but haven't found anything definitive. What I would like to do is spray my brackets from a gun, not a spray can. I've concluded that 30 percent is the right gloss. I would like to know what paint I should use that I can buy in Ca. that I can flatten to the desired results and have durability.
The Eastwood Underhood Black says 10-20 percent and is acrylic lacquer. I'm told it chips easily but I see Eastwood claims to have changed it's formula to combat this. Has anyone used this with good results. What did you use? thanks
Re: painting brakets and pulley's [Re: 70SportSatellite] #246990
03/08/09 02:25 PM
03/08/09 02:25 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
My observation is that chipping usually comes from the paint being too thick.
I would buy a can of ppg delstar and some flattening agent and play with it. If you want to spend a little more money buy some DCC urethane.
Powdercoating is the most durable solution, but you can't control the gloss factor with it like you can with paint.
Re: painting brakets and pulley's [Re: Neil] #246991
03/08/09 05:27 PM
03/08/09 05:27 PM
Warrenton, VA
RoadRunnerJD Offline
Warrenton, VA
I would not go 30% flat! Just use Eastwood underhood black. It's easy, sprays nicely and looks great. I have my pulleys, fan and brackets powder coated semi gloss. It looks fine if it's a little glossy but not too good if it's too flat. You don't want your radiator too flat either. I would stay away from trying to do a certain percent flattener. It's tricky and there are plenty of good paints out there of varying glosses.
