Pipe Max: how to use #2469610
03/21/18 11:13 AM
03/21/18 11:13 AM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
Thought i would start a thread on this as i can find no directions on how to calc all the possible info here. Post what ever you have figured out. I have still not figured the VE%. They only let you input head flow at max lift to get your VE% to input in the box for VE. My head flow is 356@.800" lift. That gives me 107.9% VE, which can't be correct because pipe max computes that to 800+hp in my pump gas 511. That to me is at least 100hp off. There must be another way to figure this or am i doing something wrong?
Re: Pipe Max: how to use [Re: mopar dave] #2469654
03/21/18 12:32 PM
03/21/18 12:32 PM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
Dave,
Larry has a forum you can join. Should be info on it with your pipemax registration. Part of the forum is visible to the public I think.
edit: http://www.maxracesoftware.com/
Doing a search on Speedtalk forum will turn up a lot of info as well.
I've not approached the VE using the headflow calculator so I'm not much help there. If you have engine dyno info, Larry recommends adjusting the VE until the output on the program matches the hp you actually got on the dyno.
Re: Pipe Max: how to use [Re: Mattax] #2469659
03/21/18 12:43 PM
03/21/18 12:43 PM
Mt Morris Michigan
Mt Morris Michigan
Great info. Thanks. No dyno info, but using 100% VE gets in the ball park compared to other simular builds.
Re: Pipe Max: how to use [Re: mopar dave] #2471316
03/24/18 12:47 PM
03/24/18 12:47 PM
Mt Morris Michigan
Mt Morris Michigan
still trying to get logged into maxrace. Having some trouble. Looks like no one else here using pipe max has figured out much about it either.
Re: Pipe Max: how to use [Re: mopar dave] #2471324
03/24/18 01:12 PM
03/24/18 01:12 PM
Mt Morris Michigan
Mt Morris Michigan
Sent them an email. Will see what I get from that. My user name and password not working.
Re: Pipe Max: how to use [Re: mopar dave] #2471378
03/24/18 03:41 PM
03/24/18 03:41 PM
AndyF Offline
AndyF  Offline
PipeMax only knows what it is told. 356 cfm @ 0.800 lift is good for 800 hp on a 5111 short block so PipeMax is giving you a correct answer for that input. But you have to be smarter than the software. Do you have a 0.800 lift cam? If not then the flow at 0.800 doesn't matter.
Re: Pipe Max: how to use [Re: AndyF] #2471423
03/24/18 05:52 PM
03/24/18 05:52 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Have you changed computers since you bought
the pipemax program.. every time you change
computers you HAVE to contact pipemax to get
a new pass into it.. I have had to 4 times
wave
Re: Pipe Max: how to use [Re: AndyF] #2471520
03/24/18 08:42 PM
03/24/18 08:42 PM
Mt Morris Michigan
Mt Morris Michigan
for the VE calc pipemax asks what the head flow was at .800" lift, so that what i gave. I see what you mean though. thanks
Mike, had it updated last year with a new number. Just sent them another email. Thanks
Re: Pipe Max: how to use [Re: mopar dave] #2473188
03/28/18 08:54 AM
03/28/18 08:54 AM
Victoria, Australia
Ian Offline
Ian  Offline
Victoria, Australia
dave i have a convo and some info on speed talk on ve you should read only a couple of pages in and you need net flow intake carb and net lift cheers http://www.speedtalk.com/forum/viewtopic.php?f=1&t=52699
1.37 60 ft [email]6.0@113[/email] [email]9.57@141[/email] 408 glide 3550lbs
new video http://www.youtube.com/watch?feature=player_embedded&v=Xvq3ZObywQE
Re: Pipe Max: how to use [Re: Ian] #2473277
03/28/18 12:48 PM
03/28/18 12:48 PM
Mt Morris Michigan
Mt Morris Michigan
Thank you. I'll check that out.
Re: Pipe Max: how to use [Re: mopar dave] #2473426
03/28/18 06:03 PM
03/28/18 06:03 PM
est
huimerind Offline
huimerind  Offline
est
It would be a good question for Larry.
I think that in older versions, up to 3.85
The VE calc was flow with manifold/carb at max lift times .87
Now in version 3.98, it changes with other inputs?
As an example, with 1.3" lift it calculates Ve% from 1.4967" lift .
Seems like something I would like to know smile
Re: Pipe Max: how to use [Re: mopar dave] #2473459
03/28/18 07:06 PM
03/28/18 07:06 PM
Mt Morris Michigan
Mt Morris Michigan
Received an email back from Larry telling me to use max 725hp to compute the VE with my 511 combo. I'll play with that again when i get a chance. Thanks
Re: Pipe Max: how to use [Re: AndyF] #2473737
03/29/18 10:22 AM
03/29/18 10:22 AM
Mt Morris Michigan
Mt Morris Michigan
No, the cam is a .650" on the intake lobe. The flow numbers that Todd@compititionwedge gave me on these E MW heads are 356@.650-356@.700-356@.750 and 356@.800.
Re: Pipe Max: how to use [Re: mopar dave] #2473741
03/29/18 10:40 AM
03/29/18 10:40 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
WOW!!!!!!!!!!! That's odd.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Pipe Max: how to use [Re: pittsburghracer] #2473744
03/29/18 10:46 AM
03/29/18 10:46 AM
Mt Morris Michigan
Mt Morris Michigan
I agree, but its what he said they were. Looks like to get 725hp@6800rpm the VE would have to be 96% with this combo. Bump that up to 7000rpm and 96% VE gives 750hp. Not sure where the peak HP will be with these heads and cam.
Re: Pipe Max: how to use [Re: mopar dave] #2473957
03/29/18 06:35 PM
03/29/18 06:35 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
If you have a SpeedTalk login, you may get something out of this thread that got moved to the Advanced Tech forum: http://speedtalk.com/forum/viewtopic.php?f=15&t=49826
There was some PipeMax stuff brought into it at various points. Maybe it will help...
Re: Pipe Max: how to use [Re: BradH] #2474010
03/29/18 08:12 PM
03/29/18 08:12 PM
Mt Morris Michigan
Mt Morris Michigan
I don't at the moment, but maybe i can get an account started. Thanks Brad
