Piston Identification? "992P" Found In 360 #2468804
03/19/18 10:16 PM
03/19/18 10:16 PM
here.
Remy-Z Offline OP
Remy-Z  Offline OP
here.
In the middle of a 360 build. Pistons that came out look like stockers, but are larger (my calipers are reading about 4.036) and have "992P" raised up on the inside of the skirt. I have no visible identification marks for overbore on the piston anywhere. Anybody have any ideas?
(Asking now before I take a two-hour drive to my machine shop.)
Re: Piston Identification? "992P" Found In 360 [Re: Remy-Z] #2468818
03/19/18 10:47 PM
03/19/18 10:47 PM
South Bend
John Brown Online content
John Brown  Online Content
South Bend
Re: Piston Identification? "992P" Found In 360 [Re: Remy-Z] #2468847
03/19/18 11:42 PM
03/19/18 11:42 PM
PA
Cudaful Offline
Cudaful  Offline
PA
Re: Piston Identification? "992P" Found In 360 [Re: Cudaful] #2468903
03/20/18 02:09 AM
03/20/18 02:09 AM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
Re: Piston Identification? "992P" Found In 360 [Re: Remy-Z] #2469030
03/20/18 11:57 AM
03/20/18 11:57 AM
From the link John posted, the 992P is a sealed power number (tho that one ain't a SB or possibly even a Mopar piston). What you have I'd say a garden variety 30 over sealed power cast piston. Any valve reliefs on top?
Re: Piston Identification? "992P" Found In 360 [Re: RapidRobert] #2469184
03/20/18 03:40 PM
03/20/18 03:40 PM
dogdays Offline
dogdays  Offline
Blazin' Bob, you didn't go to the ebay link. There you see the 992P is an Ertel part number for a 360. There were several piston manufacturers around back in the day: Ertel, Zollner, Nylen, Badger, Sealed Power, etc. Their part numbers were all over the map. Confusing at best.
One measures the piston diameter at the skirt about an inch up from the lowest point. If there was a manufacturer's catalog it'd say exactly where. If the OP has already measured 4.036 on the piston, the piston is most likely 0.040 over. The cast pistons with steel "autothermic" inserts were usually installed with 0.001" clearance.
R.
Re: Piston Identification? "992P" Found In 360 [Re: Remy-Z] #2469530
03/21/18 02:39 AM
03/21/18 02:39 AM
here.
Remy-Z Offline OP
Remy-Z  Offline OP
here.
No valve relief, but the caliper doesn't lie: 4.040. For once, I'm pleasantly surprised with what I find in an engine. Thanks for the help!
Re: Piston Identification? "992P" Found In 360 [Re: Remy-Z] #2469686
03/21/18 01:31 PM
03/21/18 01:31 PM
Enjoy it while it lasts!. Yes I missed the measurement you posted, My buddy Dog is keeping me straight (as usual!).
