What kind of power / torque should it make? #2469133
03/20/18 02:27 PM
03/20/18 02:27 PM
MI
MI Mopar Works Offline OP
MI
I putting a low buck 360 street/ strip engine together for my Mirada and want to know what you think it should make for power and torque.
.040 over 360 LA block
.010 off deck for zero deck height with Speed Pro Hypereutectic pistons # H116CP4. Should be around 9.8:1 - 10.0:1 Comp ratio
Stock cast crank and rods
Comp hydraulic flat tappet cam #274H
0.488 int./0.491 exh.
230 int./236 exh @.050
110 LSA
Box stock Edelbrock Performer RPM 60779 cylinder heads
Box stock Edelbrock RPM air gap dual plane intake manifold
Comp Cams Pro Magnum roller rocker arms 1.5 ratio
Moroso 8 qt. oil pan and pickup, Melling HV oil pump
Quick fuel SQ750 double pumper carb, mechanical Edelbrock fuel pump
MSD billet distributor and wireset.
Hedman full length headers 1 7/8 primaries
I do plan on a chassis dyno session after everything is broken in and close on tune.
What will it make?
MI Mopar Works (734)624-2212
Parts Sales
Restoration and detailing of all kinds of mopar hardware
https://www.facebook.com/MIMoparWorks/
Re: What kind of power / torque should it make? [Re: MI Mopar Works] #2469149
03/20/18 02:51 PM
03/20/18 02:51 PM
Keymar, MD
DusterKid Offline
DusterKid  Offline
Keymar, MD
I'm thinking right around 400HP.
I had a very similar build
360 .040 over, same pistons but .005 in hole
Felpro headgaskets (.039)
Stock crank, rods and rockers
Stock OOTB box 60779 Eddy heads
Comp Cams .519/.524 cam
Victor 340 Intake
750 Holly DP
Was in a A body with Summit 1 5/8 headers and 18" mufflers
Never dyno'd it, but went a best of 11.509 in the 1/4, but typically ran 11.60-11.70's. According to the Wallace racing calculator right in the 390-410 flywheel HP.
Re: What kind of power / torque should it make? [Re: MI Mopar Works] #2469170
03/20/18 03:22 PM
03/20/18 03:22 PM
It wouldn't surprise me that it makes between 400 and 450 HP and more torque than HP at the flywheel, the rear wheel HP and torque will be influence greatly by the converter loss and drive train friction loss shruggy
Re: What kind of power / torque should it make? [Re: MI Mopar Works] #2469176
03/20/18 03:30 PM
03/20/18 03:30 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
411 flywheel
Re: What kind of power / torque should it make? [Re: MI Mopar Works] #2469266
03/20/18 05:53 PM
03/20/18 05:53 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
Closest without going over:
375 hp
430 tq
Mo' Farts
Moderated by "tbagger".
Re: What kind of power / torque should it make? [Re: Grizzly] #2469295
03/20/18 06:45 PM
03/20/18 06:45 PM
MI
MI
Ok, some good responses here. I am hoping for a solid 400-425 HP engine for now with enough torque to have some fun on the street at lower RPM's. The rest of the combo is pretty street friendly with a stockish 727 with a 10.5" 3000 stall converter and a 8 3/4 3:91 axle and drag radials. The car is a heavy pig though because its a Dodge Mirada. I'm hoping for mid 12's once the car is dialed.
Parts Sales
Re: What kind of power / torque should it make? [Re: MI Mopar Works] #2469301
03/20/18 06:53 PM
03/20/18 06:53 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
You shouldn't have any problem running 12.50's or faster with that combo.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: What kind of power / torque should it make? [Re: Cab_Burge] #2469337
03/20/18 07:52 PM
03/20/18 07:52 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
It wont come remotely close to 450. Would bet any amount of money on that.
I would guess 380- 385 ish
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: What kind of power / torque should it make? [Re: MI Mopar Works] #2469366
03/20/18 08:56 PM
03/20/18 08:56 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Nice job! Should run good and make 400 easy.
Re: What kind of power / torque should it make? [Re: B3422W5] #2469484
03/21/18 12:39 AM
03/21/18 12:39 AM
How much money are you willing to loose? whistling devil grin
I've made 430 HP with all NHRA legal parts twenty years ago on two different 1971 340 motors with two different pairs of iron stock J and X heads shruggy
If I can do that so can most other engine builders with similar parts shruggy
The OP has a lot better parts and more C.I. to start with, hence my guestimate shruggy
The last pump gas stroker 340 motor I did in SO CA made 525 HP with a mild set of race W2 iron heads with 9.4 to 1 compression using CA 91 octane pump swill, the new Eddy 340 aluminum heads are better than those heads where shruggy
