Custom Autosound USA-630 Install? #2468697
03/19/18 06:39 PM
03/19/18 06:39 PM
Newark Valley, NY
jim6346 Offline OP
jim6346  Offline OP
Newark Valley, NY
Has anyone installed one of these into a 70 Cuda dash? It was supposed to be a direct fit, but for the life of me I can not figure out how to secure the front, as it just slides into the opening . I may be having a brain fart or am I missing something? The instructions show nothing about installing it, and their tech support wasn't very good, all they said was "you should have looked into that before ordering"....
Thanks,
Re: Custom Autosound USA-630 Install? [Re: jim6346] #2468708
03/19/18 07:16 PM
03/19/18 07:16 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Maybe it goes in from the rear like the original?
Re: Custom Autosound USA-630 Install? [Re: jim6346] #2468787
03/19/18 09:42 PM
03/19/18 09:42 PM
Newark Valley, NY
jim6346 Offline OP
jim6346  Offline OP
Newark Valley, NY
Hi,
Yeah, I installed it from the rear, but no way to secure the front of the radio. The back is help with a bracket.
Thanks,
Re: Custom Autosound USA-630 Install? [Re: jim6346] #2468805
03/19/18 10:19 PM
03/19/18 10:19 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
Somebody cut your dash out before you got the car?
Robert
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: Custom Autosound USA-630 Install? [Re: jim6346] #2469265
03/20/18 05:47 PM
03/20/18 05:47 PM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
it bolts in from the lower front sides
5549 post on old board
Re: Custom Autosound USA-630 Install? [Re: 05dakota] #2469269
03/20/18 06:00 PM
03/20/18 06:00 PM
Omaha Ne
TJP Online content
TJP  Online Content
Omaha Ne
We have found their units to be pretty poor quality. I would suggest returning it if at all possible and going with
http://www.radiosforoldcars.com
A bit pricier but much higher quality and they look a lot more original. Classic industries normally ha them in stocak
Re: Custom Autosound USA-630 Install? [Re: jim6346] #2469668
03/21/18 12:57 PM
03/21/18 12:57 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
If the first picture of the radio is the one you have. It looks like you can swap the black plastic façade out with a slightly larger home made one possibly backed by a sheetmetal plate.
You can get that textured plastic from Tap Plastics and cut it to fit. I used a similar technique to mount my Vintage Air control panel in my dash.
These days though, I'm not sure why anyone would not use their smart phone with Bluetooth, Pandora, an amp and hidden speakers for a completely invisible vastly superior sounding system.
Or do what I do and throw a portable Bluetooth speaker in your car an use your smart phone to drive it. I can use the same speaker in the garage, the house or wherever. They are getting really good these days.
