When it rains, it pours #2469147
03/20/18 02:49 PM
03/20/18 02:49 PM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
A little maintenance this Spring I thought. New valve springs, tires, have a look at the bearings, trans, and shocks. Trans looks ok except a pile of metal on the magnet. Reaction shaft support and rings are toast. At least the rest looks like new (350passes). Found bad threads in #3 hole during comp testing. #3,#4 mains look a little suspect. Pull the motor. Water pump is coroded next to the motor plate, disassemble and mill flat. Pull the crank for mag, it's cracked, order a new Molnar piece. Rear coil springs are bent, rubbing on the shock, order new parts. Front shock leaks. Pull all 4, fronts will be rebuilt. Dyno the rears, curve is out to lunch. We'll see what happens when they come apart. Ok at least I'll clean the bottom of the car while I wait on parts. Oh , what is this? A cracked front frame rail. Now the entire front suspension gets pulled for access. Aren't race cars fun? Good thing I had some wins last year.
Doug
Re: When it rains, it pours [Re: dvw] #2469160
03/20/18 03:03 PM
03/20/18 03:03 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Wow, sorry to hear about all the trouble. Thats how my luck was last year just getting the 511 in and tuned. How your luck gets better soon.
Re: When it rains, it pours [Re: dvw] #2469183
03/20/18 03:40 PM
03/20/18 03:40 PM
ohio
67mprfan Offline
67mprfan  Offline
ohio
But your car was working great with all you found now just imagine how much better it's going to perform
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it.
67 Belvedere that worked it's way in the 10's
Re: When it rains, it pours [Re: dvw] #2469190
03/20/18 03:45 PM
03/20/18 03:45 PM
central ohio
N
nss guy Offline
nss guy  Offline
N
central ohio
Dang someone's going to be busy.
Still plenty of time
Re: When it rains, it pours [Re: nss guy] #2469199
03/20/18 03:52 PM
03/20/18 03:52 PM
fullmetaljacket Offline
Always take second looks, first time.
A lot of what you found could have turned its nasty head into a catastrophe, so you caught it in the first stages.
Yeah, fix it good and give it a multi-point annual check up before any race from here on then, though it looks like you already do that anyway.
Doug, I'm glad you caught Murphy.
Re: When it rains, it pours [Re: dvw] #2469200
03/20/18 03:54 PM
03/20/18 03:54 PM
an8sec70cuda Offline
Ouch, good luck getting it back together! What brand of crank was it that cracked? How many passes on it?
CHIP
'06 GMC 2500HD LBZ Duramax
Re: When it rains, it pours [Re: dvw] #2469215
03/20/18 04:30 PM
03/20/18 04:30 PM
Minn
SportF Offline
SportF  Offline
Minn
Doug, sorry about your luck, but then, lucky you caught it.
Would you care to share with us where the frame cracked. It would help some of the rest of us know where to really look hard.
Best of luck, I am sure we'll see you racing.
Re: When it rains, it pours [Re: dvw] #2469221
03/20/18 04:45 PM
03/20/18 04:45 PM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
Crank originally came from Indy, no name but it has Pentastar on it. It was used and the thrust suface and #3 was burned when I got it. Polished then put 500 passes on it. Before that??
Doug
Re: When it rains, it pours [Re: dvw] #2469231
03/20/18 04:54 PM
03/20/18 04:54 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
Better to find it now than at the top end when you drive over your own crank! I would say that crank owes you nothing!
Re: When it rains, it pours [Re: dvw] #2469279
03/20/18 06:20 PM
03/20/18 06:20 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Bummer Doug.. you have some work ahead of you..
good luck with it
wave
Re: When it rains, it pours [Re: dvw] #2469351
03/20/18 08:20 PM
03/20/18 08:20 PM
Alberta
Wookie316 Offline
Wookie316  Offline
Alberta
Yes. Was putting rockers on this weekend to get motor running. When I was baring motor over to set valves a bunch of water came out of spark plug hole #4.
So tore the head off. At the shop to be pressure tested. Awaiting the results.
Glad I checked now vs 3 weeks from now. At least I have ample time to get it sorted.
1971 Plum Crazy Super Bee. 572 World Aluminum block with a Cope 727 & Dana 4.10 out back. 9.88 @ 138 with a 1.35 60 NA. Dialed back to 10.0’s. 4000 lbs with me in it.
Re: When it rains, it pours [Re: Wookie316] #2469358
03/20/18 08:40 PM
03/20/18 08:40 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Damn Doug you got rocked. I’m sure you will have it up and running again in no time. Great catch. Are you coming to Pittsburgh this year. Hope to have a beer with you.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: When it rains, it pours [Re: dvw] #2469383
03/20/18 09:28 PM
03/20/18 09:28 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
This stuff is high maintenance. Time and money. You did it right, finding the problems before they bite you.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: When it rains, it pours [Re: dvw] #2469401
03/20/18 10:00 PM
03/20/18 10:00 PM
Fancy Farm Ky
W
wyoming Offline
wyoming  Offline
W
Fancy Farm Ky
As mentioned, better to find now than going down the track, sounds like a good inspection, get her done
Re: When it rains, it pours [Re: dvw] #2469405
03/20/18 10:04 PM
03/20/18 10:04 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
When people complain that their cars don't run right, or constantly breaking, this is how you stay in front of it. Good catch on all.
[image][/image]
Re: When it rains, it pours [Re: sgcuda] #2469413
03/20/18 10:28 PM
03/20/18 10:28 PM
birdtracker Offline
birdtracker  Offline
Doug: glad you found it now instead of later. I would trade all your problems for my one. Hopefully see you at Norwalk. Birdtracker
Re: When it rains, it pours [Re: dvw] #2469422
03/20/18 10:50 PM
03/20/18 10:50 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Actually pouring down rain here now... I too have a car with multiple "problems" that won't be raced without some serious time and money. You found some weak area's that need attention. Good job! up It's amazing the things that call for attention when you are right there with a wipe rag. I used to remove the back tires (kind of a PITA) and wipe down the ENTIRE car after every race. I slacked on it the last few years racing it so gently in S/ST on the Div. trail. Now it needs everything! "And while I'm at it I really want to do this" snowballs into my brain and GOOD GOD it's NEVER ending!
haha
Re: When it rains, it pours [Re: dvw] #2469436
03/20/18 11:19 PM
03/20/18 11:19 PM
Spahn Ranch
RMCHRGR Offline
RMCHRGR  Offline
Spahn Ranch
Cracked front frame rail? That sounds bad.
'71 Duster
'17 Ram 1500
Re: When it rains, it pours [Re: RMCHRGR] #2469475
03/21/18 12:27 AM
03/21/18 12:27 AM
Aurora, Oh.
max_maniac Offline
max_maniac  Offline
Aurora, Oh.
WOW sorry to hear this Doug BUT like everyone said good thing to find out now. Take your time and get it right and can't wait to see you at the track again!!!
Re: When it rains, it pours [Re: dvw] #2469619
03/21/18 11:27 AM
03/21/18 11:27 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
back her down to a mid 10 combo and a lot of those problems will go away! laugh2
