Mocked up my Hughes Girdle #246891
03/08/09 01:07 PM
03/08/09 01:07 PM
Finally a HUSKER again
Moparnut426 Offline OP
I got everything mocked up last night, I cleaned all threads, instakked the studs, and made sure the girdle was installed according to Hughes specs. After I got the block back from the machine shot from being honed with a torque plate I did find 3 of the shors head studs were removed with a DAMN VISE GRIP!! garred up the studs pretty badly, and accually dug into the thread of the studs. Why use a vise grip when there is a place for an allen wrench on the top, is beyond me. Should I replace the damaged studs, or run them, Im sure they are find, but the stress risors do concern me a bit.
All in all the Girdle went on pretty good. I ended up useing .263 thick spacers, and only had to clean casting numbers off 3 main caps. Should I have a machinist friend of mine make me 8 one piece hardened spacers and not use the 3 spacers I used out of the kit?
Thanks Guys
Kasey
Re: Mocked up my Hughes Girdle [Re: Moparnut426] #246892
03/08/09 02:27 PM
03/08/09 02:27 PM
Oak Harbor, WA
W
Wicked49670dart Online mad
Wicked49670dart  Online Mad
W
Oak Harbor, WA
I used the shims that came from Hughes and have had no problems, I followed the instructions and torqued everything to their specs..Matt
70 Dart 3400 496 New Best 6.15@110.37 660ft, 9.76@135 with a 1.34 60ft
Re: Mocked up my Hughes Girdle [Re: Wicked49670dart] #246893
03/08/09 02:45 PM
03/08/09 02:45 PM
I am just worried about one of the hard spacers cracking, or a thin spacer getting squished out and causing a stud to come lose.
I tend to stress about things too much, I sure everything will be fine.
What do you guys think about the messed up studs. They are the short ones so that should be better than a long one distorting and working on the galled area.
kasey
Re: Mocked up my Hughes Girdle [Re: Moparnut426] #246894
03/08/09 03:05 PM
03/08/09 03:05 PM
MR_P_BODY Offline
MR_P_BODY  Offline
kasey
I wouldnt worry to much about it... but you will know
when you torque it down but I'm sure it'll be fine
Re: Mocked up my Hughes Girdle [Re: MR_P_BODY] #246895
03/08/09 03:14 PM
03/08/09 03:14 PM
Mr P you are probably right, Im sure the torque wrench wont click off and act like its stretching, or pulling out.
thanks
Post deleted by Defbob [Re: Moparnut426] #246896
03/08/09 03:46 PM
03/08/09 03:46 PM
Re: Mocked up my Hughes Girdle #246897
03/08/09 03:59 PM
03/08/09 03:59 PM
MR_P_BODY Offline
MR_P_BODY  Offline
thanks
You could grind and smooth out the galled areas to minimize them.
I would take a fine file and at least knock off the
high spots on the galled part
Re: Mocked up my Hughes Girdle [Re: MR_P_BODY] #246898
03/08/09 04:03 PM
03/08/09 04:03 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
thanks
A fine round file and then some 220 or finer grit sand paper to polish it and make the sanding lines go up and down on the stud not around it.
Re: Mocked up my Hughes Girdle [Re: HotRodDave] #246899
03/08/09 08:12 PM
03/08/09 08:12 PM
Well I used a brown roll lock pad, and cleaned them up. They should be ok now.
Re: Mocked up my Hughes Girdle [Re: Moparnut426] #246900
03/08/09 08:31 PM
03/08/09 08:31 PM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
on heat treated steel. did it polish it? J/K
