I got everything mocked up last night, I cleaned all threads, instakked the studs, and made sure the girdle was installed according to Hughes specs. After I got the block back from the machine shot from being honed with a torque plate I did find 3 of the shors head studs were removed with a DAMN VISE GRIP!! garred up the studs pretty badly, and accually dug into the thread of the studs.
Why use a vise grip when there is a place for an allen wrench on the top, is beyond me. Should I replace the damaged studs, or run them, Im sure they are find, but the stress risors do concern me a bit.
All in all the Girdle went on pretty good. I ended up useing .263 thick spacers, and only had to clean casting numbers off 3 main caps. Should I have a machinist friend of mine make me 8 one piece hardened spacers and not use the 3 spacers I used out of the kit?
Thanks Guys
Kasey
