Trailer Advice - Whats on your wish list? #2468572
03/19/18 01:48 PM
03/19/18 01:48 PM
Renton Washington
Triple Threat Offline OP
Renton Washington
A buddy and I are looking at ordering new enclosed gooseneck trailers. What are your must haves? If you were making a wish list what would be on it?
We're looking at 42-44' trailers with bathrooms and a bed in the riser area.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Trailer Advice - Whats on your wish list? [Re: Triple Threat] #2468581
03/19/18 02:21 PM
03/19/18 02:21 PM
Locomotion Offline
Locomotion  Offline
That sounds like something I've been fantasizing about if I ever win the lottery!
* Triple 6000 lb axles w/16" tires - 15" tires blow out too much and main reason for triple axles is that if your in an area where you can't pull off to change a flat/blown tire, the 2 remaining tires will help support the trailer without being overloaded by the time you find a spot. (Of course triple axles will be tough your on the wallet if you travel over toll roads a lot.)
* Dual halogen lights outside.
* Dual electrical outlets outside & multiple interior. (Box fan, battery charger, etc.)
* Generator/box.
* Dual in-floor spare tire storage. Good for tool storage too even if you dont carry 2 trailer spares.
* I've been thinking that a roof hatch in the riser area might come in handy some day.
* As much storage cabinets and wall racks as possible.
* High wall slick mounts.
* Iffy on a winch. I carry a few good come-a-longs.
* Escape door properly positioned for full car door opening clearance.
* I think the rubber "coin" floor is more durable than vinyl flooring.
* Diamond plate rectangles positioned for each tire. (Possibly raised if needed to help the door clear, but you can only go so far if the car is low.)
* Overhang or big drip rail above the ramp door to minimize rain from getting in the door seams and possibly latch mechanisms. (Had a hinge support area rust out because water got inside the ramp.)
* Heat/A/C.
* Had an awning on my 28' tag, but it was a pain & was removed after it got damaged.
* Always get a little more length than what you "think" you'll need.
Probably more ideas if I had time to check out more options.
Post pics when you get it!
Re: Trailer Advice - Whats on your wish list? [Re: Locomotion] #2468587
03/19/18 02:33 PM
03/19/18 02:33 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Make sure you read up on the upcoming CDL rule changes. X amount of weight and boy are you on their radar. Going after horse trailers big time
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Trailer Advice - Whats on your wish list? [Re: Triple Threat] #2468590
03/19/18 02:45 PM
03/19/18 02:45 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Beside the usual things, ac/heat, Gen compartment, 16" tires, etc. The stuff that is generally in every trailer.
These are things I will have in my next trailer the end of this year. LED lighting everywhere(as much 12 volt as possiblwe) to including outside. Wheel well cabinets, a fold down table. TV/Monitor and sound system inside and out. As much cabinetry as you can fit in the trailer, overhead and base cabinets as well as overhead on opposite side of wheelwell cabinet. Storage for things like ratchet straps, portable awnings, chairs, oil etc, I like having a closet to hang my gear, a winch compartment either under cabinet or in floor, and a toolbox under the counter top. Extended rear ramp to ease loading and unloading. Rear loading lights. Plumbed for air outside and inside and room for under cabinet compressor. 35 or 50 amp service for shore power. As large and inverter as I needed. Think that's most of it. Id like to have a good awning that attached to trailer and storage for that too, get tired of the portables.
Re: Trailer Advice - Whats on your wish list? [Re: Triple Threat] #2468595
03/19/18 02:52 PM
03/19/18 02:52 PM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
I had a 34 foot tag with living quarters. In part due to the weight and the stories about state patrol, giving tickets for cdl, weight etc. I sold it and got a 26 foot tag, and a crank up slide in camper for the truck to stay in at the races. Believe it or not the rig now weighs 2,000 lbs less, than the 34 trailer. My camper has a queen bed, A/C, furnace bathroom with shower, when it is cranked down its the same height as the trailer, improving fuel mileage. I been averaging 13 mpg, Plus I can take just the camper fishing when I want to. Also most highway patrol see a slide in camper pulling a smaller tag trailer with no decals, might think it has a ranger or other 4 wheeler in it, not a race car. I did buy an extended tongue on the trailer to keep the everything in clearance on tight turns. I always like storage in the floor for spare tires and other stuff. 16 inch tires and a fat man door to get in the car when loading.
Re: Trailer Advice - Whats on your wish list? [Re: Triple Threat] #2468613
03/19/18 03:28 PM
03/19/18 03:28 PM
Taxes & Virus's R-US, NY
Dragula Online content
Dragula  Online Content
The one thing nobody offers....A drivers side escape door on a bathroom trailer along with a slide out generator door...
I want one with all three, and it seems its impossible unless I order a $40k trailer.
Re: Trailer Advice - Whats on your wish list? [Re: Dragula] #2468683
03/19/18 06:06 PM
03/19/18 06:06 PM
my own world
theraif Offline
theraif  Offline
my own world
well if we are talking lotto money hehehe
for those who dont follow dirt racing
Re: Trailer Advice - Whats on your wish list? [Re: Triple Threat] #2468695
03/19/18 06:35 PM
03/19/18 06:35 PM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
besides the stuff already listed, if I ordered a new trailer today, I would 17.5 wheels and tires and a air ride suspension. The air ride would allow me to lower the trailer once I got to the track, make off loading car easier and jumping in and out 100 freaking times a day less of a work out for this old man.
Joe
Without Data, you’re just another guy with an opinion.
Re: Trailer Advice - Whats on your wish list? [Re: pittsburghracer] #2468929
03/20/18 03:40 AM
03/20/18 03:40 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
This definitely depends on what part of the country you are in. Penn is a whole lot different from the west. They fire up those steel plants yet? grin
Re: Trailer Advice - Whats on your wish list? [Re: Triple Threat] #2468938
03/20/18 04:08 AM
03/20/18 04:08 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
https://www.racingjunk.com/Trailers-with...p;from=search#4
This is our “wish trailer”. It’s also high enough that we could throw the Jeep in it and spend some weekends in the cooler high country in the summer. Also like that it has room in front of the cabinets for the golf cart. Would also be easier to cool the sleeping area.
Someday..... smile
Re: Trailer Advice - Whats on your wish list? [Re: J_BODY] #2468961
03/20/18 09:05 AM
03/20/18 09:05 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Someday..... smile
Been looking at that exact trailer for over a year now. Layout is perfect for what I'm looking for. Just needs a roof air, heat, and a fridge.
69 GTX 68 Road Runner
Re: Trailer Advice - Whats on your wish list? [Re: JERICOGTX] #2469048
03/20/18 12:23 PM
03/20/18 12:23 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Got me an old 28' Haulmark. Just get as big as you can afford. You can always add things as you go. That is what I have been doing. Mine was too good of a deal to pass up. I have repainted the entire inside white, added overhead aluminum cabinets, battery box & winch, electric tongue jack and being that i am in the hood I added latches that i lock from the inside so even if someone snips the padlocks off of the big rear door they still cannot open it from the outside.
I also use the electric tongue jack as a anti-theft device in addition to the tongue lock. Jack it up as high as it will go & pull the fuse which is hidden in the harness. Then no one else can lower it onto their truck to be able to drive away. I also wrap chains thru the wheels & lock them together.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Trailer Advice - Whats on your wish list? [Re: Triple Threat] #2469059
03/20/18 12:30 PM
03/20/18 12:30 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Dustin has a 28'(I think) trailer currently. I can understand wanting more. I waffled between a large living quarters trailer and shorter trailer and motorhome. I ended up with the latter.
Definitely an electric tongue jack, because I'm old and lazy. We lower ours all the way and remove the power to it.
Re: Trailer Advice - Whats on your wish list? [Re: Triple Threat] #2469068
03/20/18 12:39 PM
03/20/18 12:39 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Electric tongue jack is a must have for most enclosed trailers, and really every Gooseneck trailer it should be standard. The LQ trailer vs. Motorhome/Tag combo, is really up to what do you do other then go racing? I also have a 24' open trailer to haul my SkidSteer, so I still need a diesel truck. I'm also thinking long term. When I retire, I want to head south for the winter, and race my way north as the weather gets nice, and enjoy as many tracks as I can. Since it's just me, I don't need a ton of living space.
Re: Trailer Advice - Whats on your wish list? [Re: Triple Threat] #2469076
03/20/18 12:46 PM
03/20/18 12:46 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Oh I still have a diesel dually too as does my son smile
Re: Trailer Advice - Whats on your wish list? [Re: Al_Alguire] #2469078
03/20/18 12:48 PM
03/20/18 12:48 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Never buy a Pace trailer, POS to the MAX! my beater (2015) 24' enclosed with 2' v-nose has broken down three times now. Also, NEVER buy spring axle trailers, only torsion axle... twocents
JB Rhinehart, Realist
A-Body's RULE!
Re: Trailer Advice - Whats on your wish list? [Re: theraif] #2469086
03/20/18 12:59 PM
03/20/18 12:59 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I wonder if Bloom paid for that with all the money he mad years ago hauling dope?
Re: Trailer Advice - Whats on your wish list? [Re: Triple Threat] #2469118
03/20/18 02:05 PM
03/20/18 02:05 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
Lots of great suggestions. I would definitely get a winch, dual batteries, a shower,12v LED lighting, and an aluminum trailer.
Right now I think InTech builds my favorite trailer.
Re: Trailer Advice - Whats on your wish list? [Re: Al_Alguire] #2469128
03/20/18 02:19 PM
03/20/18 02:19 PM
Renton Washington
Renton Washington
Correct, 07 28' Pace currently. I spend about 25 weekends a year at the racetrack (our season is short) so having some more amenities would be nice. Not required, but would be nice. If we can find something at a fair price point we're planning to pull the trigger on two.
We've been window shopping the various trailers on RJ like what Jay posted, those are in the realm of what we're after. Currently exploring a few different quotes from a few different sources and manufacturers, some which think the trailers are made of gold, rather than steel. Aluminum isn't in the budget so ATC, Intech, T&E and Goldrush are off the table.
A personal favorite of mine:
https://www.racingjunk.com/Trailers-with...from=category#2
-Dustin
Re: Trailer Advice - Whats on your wish list? [Re: 340Cuda] #2469131
03/20/18 02:25 PM
03/20/18 02:25 PM
PA.
"Little"John
"Little"John
PA.
I ordered and picked up my trailer last year but it’s a lot smaller than the one you are looking for (26 footer). I had it wire for a stereo with four speakers and out side antenna. Then I wired in my stereo. I had a mouse hole installed for a winch and put mine in. Garment closet worked out very nice because a 30 gallon fuel barrofits perfect with lots of extra room. Inside light and extra electrical outlets. One electrical outlet up front outside. Two quarts 500 watt lights which I later bought led lights for. Rubber coin floor then I mounted diamond plates where the tires sit. 16 inch wheels and tires. Smooth side no rivets. 4 foot side door. Workbench and I wired in an inverter.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
