Lexan windshields #2468272
03/18/18 08:26 PM
03/18/18 08:26 PM
s.e. michigan
top8x7b Offline OP
top8x7b  Offline OP
s.e. michigan
Who did you guys use ?
For a 70 duster
Re: Lexan windshields [Re: top8x7b] #2468324
03/18/18 09:54 PM
03/18/18 09:54 PM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
Made my own. Got sheets of 1/8" lexan and used the old glass as a pattern. Taped up the border and spray painted it with Krylon. Take your time and cut it slow with a very fine toothed jig saw or band saw if available. Rough out the blank and support it on a flat table (like 1/2" plywood on saw horses) to finish cutting it. Key point here, TAKE YOUR TIME.
Brian
Re: Lexan windshields [Re: top8x7b] #2468518
03/19/18 11:41 AM
03/19/18 11:41 AM
an8sec70cuda Offline
Maybe I'm biased b/c my personal cars are still street legal and have the factory glass in them, but I hate looking through lexan. The stuff is horrible to see through at night, scratches so easily, and generally looks terrible IMO.
Taking the lexan out of the Camaro I drive for a friend and putting a real windshield back in it.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Lexan windshields [Re: an8sec70cuda] #2468551
03/19/18 12:53 PM
03/19/18 12:53 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
You're either using the wrong stuff or not taking care of it right. You can't treat it like glass.
Re: Lexan windshields [Re: CMcAllister] #2468554
03/19/18 01:00 PM
03/19/18 01:00 PM
fullmetaljacket Offline
Agreed.
it must be taken care of with tender glove's.
No wipers scuffing across, so watch your weather forecast.
Lexan here for 10 years + and still looks as clear as glass. Even at night. 3/16's.
Good weight savings right up front.
Re: Lexan windshields [Re: CMcAllister] #2468555
03/19/18 01:00 PM
03/19/18 01:00 PM
Possibly, just an observation from cars I've driven and worked on for other people.
CHIP
Re: Lexan windshields [Re: top8x7b] #2468830
03/19/18 10:58 PM
03/19/18 10:58 PM
Illinois
DirtyDave Offline
DirtyDave  Offline
Illinois
First post here so if I missed the introduction section I do apologise.
http://www.proglasswindows.com
http://www.opticarmorwindows.com
Couple of the better companies out there. A little pricey but well worth it, and you definitely want coated not some crap from home depot where you even look at it wrong and it scratches.
Re: Lexan windshields [Re: top8x7b] #2469119
03/20/18 02:06 PM
03/20/18 02:06 PM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
the side and rear glass I replaced myself with flat lexan sheets, I moulded the back glass with a heat gun. The windshield I bought from proglass, good quality, and has a coating to stop scratches. Beware I had my car painted and told them they had to mask it good off, because you can't use thinner to get off overspray like glass. Well they used all tape instead of paper, and it pulled the coating off in several places, I replaced it this year, where the coating was good, no scratches after 15 years, where it was gone lots of scratches.
Re: Lexan windshields [Re: jwb123] #2469205
03/20/18 04:02 PM
03/20/18 04:02 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
We used a high quality molded 3/16" windshield on the Mustang. Don't even need to brace it. No issues at over 200 mph.
Re: Lexan windshields [Re: top8x7b] #2469214
03/20/18 04:29 PM
03/20/18 04:29 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I have been very happy with all my ProGlass stuff. Most people think it is glass, if you take care of it they will last for a very long time. I used Pro Glass because they used formed pieces for windshields rear windows etc
