Page 7 of 7 1 2 3 4 5 6 7
Re: 470 dyno test article [Re: AndyF] #2455979
02/23/18 03:18 AM
02/23/18 03:18 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Originally Posted By AndyF
I'm not sure what I'm going to do with this engine. I might just put my old cam back in it...
There's my suggestion... but you have more time & $ than I do at this point. wink
One thing I could do that might make sense would be to get another 264/268 cam ground but on a different LSA. Maybe tighten it up to 106 and see what happens. That way most of the variables would be controlled. Not sure it would worth the time and effort to do that test, but it would be a logical thing to do.
You can do it for fun, but at the HP levels that you have reached, a 106 LSA would only knock that down quite abit. So no, I wouldn't bother.
But, I would like to say thanks for all of the testing and Sharing you have done on this thread. up beer
Re: 470 dyno test article [Re: AndyF] #2456030
02/23/18 10:39 AM
02/23/18 10:39 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
I suppose it makes sense to ask where you're looking to see improvements over the 264/268 on 108...
Re: 470 dyno test article [Re: Sport440] #2456060
02/23/18 12:13 PM
02/23/18 12:13 PM
Mt Morris Michigan
mopar dave Online content
mopar dave  Online Content
Mt Morris Michigan
Thats what i have read about the narrow lobe sep, they come on quicker.
Re: 470 dyno test article [Re: BradH] #2456109
02/23/18 01:44 PM
02/23/18 01:44 PM
AndyF Offline OP
AndyF  Offline OP
All I care about is 4000 to 7000 rpm and I'll give up some lower end to raise the peak if I have to. Although that seems to be a tricky deal. Common theory is that a bigger cam will trade low end for top end but it doesn't seem to work that way in an engine like this. Too big of a cam just kills the power everywhere.
Re: 470 dyno test article [Re: AndyF] #2456119
02/23/18 02:05 PM
02/23/18 02:05 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
I've read that article a few times and I think it needs some editing for clarity. I don't think the author ever says how the cams were installed. Were they all installed straight up? He also doesn't talk about the big effect that LSA can have on valve to piston clearance. And I think some of his conclusions are wrong. He says the 101 LSA cam has a wider powerband but I think that is wrong. Looks to me like the 101 cam falls off faster than the others.
yeah, i would've liked to know where they were installed. could the 113 lsa cam be installed advanced a little to bring cranking psi up and pickup the low end quicker?
my main interest in this is I want to build a mostly street driven low deck 451 (with trick flow heads probably) and i'm thinking a cam around 112 lsa (similar to the MP 528 solid) to try to clean up the idle and low rpm cruise range some...
and then, with great heads does the the wider LSA even matter as much.
I remember there was a thread here about LSA (i think) and Monte Smith seemed to like a wider LSA if the heads were good.
Re: 470 dyno test article [Re: krautrock] #2456177
02/23/18 03:13 PM
02/23/18 03:13 PM
BradH Offline
BradH  Offline
Monte, along with some others on here, built/build serious sh!t with mega-flow heads, high CR and/or power adders, and comparatively narrow usable power ranges at high(er) RPM. When you're flying at that altitude, the "right" LSAs are in a different range than what Joe Average needs... IMO.
Junk like mine w/ moderate cubes, semi-pump gas CR, a lower RPM limit and comparatively small-port & limited-flow heads doesn't necessarily see improvements from wide(r) LSAs. This is one of those topics that I've seen David Vizard and other established engine builders having to agree to disagree on, 'cuz DV seems to lean towards as tight an LSA as possible on builds that the others just shake their heads at. "They" will say 110 or 112, and he'll say 105 or 106. He's got his methodologies, but as Andy pointed out, they're far from universally accepted.
My own tests years ago on a much milder combination than I have now didn't pan out like I'd expected. Three SFT cams dynoed on a pump-gas 440 making in the low-to-mid 500s HP:
- 251/255 on 108
- 254/254 on 108
- 255/263 on 110
For THAT COMBINATION, the 255/263 on 110 was the worst across the board. The 251/255 x 108 and 254/254 x 108 were very close with the best peak #s coming from the 254/254. However, the 251/255 revved out much farther before valve float kicked in w/ the 254/254. I went with the 254/254, but on the track when I ran shorter tires (275/60R15 drag radials vs my 29" slicks), I was getting into valve float on the big end and killing my MPH. In retrospect the smaller cam might have worked better overall in the car and not have beaten up the valve job as quickly.
None of this stuff is a "for sure" thing. And even the best educated(?) guesses of the results sometimes miss the mark by a pretty large margin vs what the real world shows.
OK, I've probably broken my soap box from standing on it so long. We now resume your regularly scheduled programming...
Re: 470 dyno test article [Re: AndyF] #2456185
02/23/18 03:28 PM
02/23/18 03:28 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
That's a BIG problem in a street and even some race cars only caring about 4000-7000 rpm's and even Jason Pettis was blown away by how well a few carbs I did worked on his dyno and had EFI throttle response and were clean through ALL of the curve not PEAK............. whistling
Re: 470 dyno test article [Re: AndyF] #2456246
02/23/18 05:22 PM
02/23/18 05:22 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
LSA........ Definitely one of those "it depends" things.
In many(most?) applications its usually a compromise based on a multitude of factors that aren't related to making the most power possible.
Re: 470 dyno test article [Re: fast68plymouth] #2456276
02/23/18 06:54 PM
02/23/18 06:54 PM
long time lurker, short time p...
P
PorkyPig Offline
PorkyPig  Offline
P
Ive been trolling speedtalk and some of the cam guys on there say they don't care about the LSA because its just a number after the opening and closing events are figured out. Then you got Vizard who tries to start with the LSA and come up with the duration from his idea of what the overlap should be for a particular use. When my head stops spinning from all this I'm going to need a bucket puke
Re: 470 dyno test article [Re: BradH] #2456384
02/23/18 11:30 PM
02/23/18 11:30 PM
Mt Morris Michigan
Mt Morris Michigan
Some interesting info there. I would like to make a correction. The Engine Masters article i mentioned earlier was run with a sb chevy, not a mopar like i thought. Early oldtimers i guess. A 355 with 10:1 comp and 190 AFR heads. They tried lobe seps from 106 thru 114 with 108 making the most peak and avg numbers. The 106 and 110 were almost the same on peak and avg numbers. They were down only 4 avg hp and 6 max hp. Just an fyi.
Re: 470 dyno test article [Re: PorkyPig] #2456390
02/23/18 11:35 PM
02/23/18 11:35 PM
I use to use Isky cams in all my builds, they had a grind called 590/616 solid lifter race cam for Mopar wedge motors that work very well in stock stroke 440 mild (under 550 HP)bracket motors, that grind was on a 104 LSA and I would normally install it from 100 to 103 ILC depending on automatic trans or stick shift trans.
I was lead to believe back in the early 1960s that the LSA, no matter the motor, determined the power band RPM limits, closer was lower RPM at peak power and wider was higher RPM at peak work confused
I gladly bought AndyF Crower 105 degree LSA solid roller SS cam that he didn't try in his testing, I also bought another Crower close LSA from another member on here who lives in Boise, ID. that was ground on 104 LSA, I will gladly use both of those cams in one of my future pump gas street and strip builds that will make over 600 HP, maybe even one for myself devil
I've use other brand of solid lifter cams ground on closer(108 or less) LSA, one was ground on a 101 LSA, for N/A BB Mopars wedge motors with stock type 440 heads and all of them worked fine up devil
I've read many discussions on here about LSA on BB Mopar wedge motors and every body has there own favorites, me included devil
On big headed motors, CNC C440-1 heads and bigger, wider LSA on long durations (285 degrees+ @.050)works fine, on stock headed motors I like closer, 108 and closer better LSA up You also need to remember the closer the LSA the less manifold vacuum you will have with the same duration camshafts and the you get a rougher, choppier idle with closer LSA and more bottom end and a lower peak HP RPM shruggy
Re: 470 dyno test article [Re: BradH] #2456650
02/24/18 02:00 PM
02/24/18 02:00 PM
gregsdart Offline
gregsdart  Offline
- 251/255 on 108
- 254/254 on 108
- 255/263 on 110
Brad, if you look at the opening closing points of the 255 vs the 254 cam, and were to install them both at say 108, the only event that changes is the exhaust opening discounting the ondegree difference in intake timing. Maybe your motor had great exhaust ports , which makes me wonder how your motor would have responded to something like a 252/248/107 or 106 lsa cam
Re: 470 dyno test article [Re: gregsdart] #2456862
02/24/18 07:02 PM
02/24/18 07:02 PM
BradH Offline
BradH  Offline
If I wanted to build something similar today, I wouldn't use any of the cams that I tested or actually ran in the car. But that's because I'd look for lobes that would be easier on the valve train due to street use. However, the duration & LSA would likely still be very close to the 254/254 on 108.
Re: 470 dyno test article [Re: BradH] #2457332
02/25/18 03:18 PM
02/25/18 03:18 PM
birdtracker Offline
birdtracker  Offline
has anyone flowed any of the 270's on a flow bench? Interested in what they should be for intakes and exhaust. thanks Birdtracker
Re: 470 dyno test article [Re: AndyF] #2468486
03/19/18 10:18 AM
03/19/18 10:18 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Originally Posted By fast68plymouth
So, peak to peak, what was the difference between the two cams?
Turns out I don't have a clean A to B test with the same exact parts on both engine due to the problems I had with the vacuum pump. I wasn't able to run the QRI cam with a vacuum pump since I had issues with it so all of my current testing is with breathers. The engine is making right around 750 hp with the QRI cam using breathers.
I made 775 hp with the HXL cam using a vacuum pump and Wilson Indy. I made 745 hp with the HXL cam using breathers but with the M1 Wilson intake. (std port intake) I never tested the HXL cam with breathers and the Indy Wilson intake so I don't have that as a baseline.
My guess is that the HXL cam with breathers and the Indy Wilson intake would hit 755 or 760 hp in an A to B test but I wouldn't be surprised to be wrong.
Another thing is the weather. The last few days have had cold air so the correction factor is negative. Even thought the correction factor is only a few percent different than the previous tests, that is enough difference to throw some doubt on the comparison.
Overall a great post AndyF! The one assumption I'm not to sure about is the tangible power 'gained' by less spring. I went back and quoted this piece to try to capture the power outputs of each combo comparatively. Although the cam may be too big, I don't see it being that far off from the last in performance IF there is a measureable 'gain' in power due to less component friction. That being said however, I feel if there is evidences of good valve control, there are many good reasons to use this type of spring over a conventional spring.
Re: 470 dyno test article [Re: AndyF] #2468562
03/19/18 01:22 PM
03/19/18 01:22 PM
AndyF Offline OP
AndyF  Offline OP
The dual conical springs have less friction than the K950 springs that were on there before so that means they will free up some power. It might be too small to measure on the dyno, or it might just get swamped by the other factors. But even if the friction is too small to be measured on the dyno you can see the result on the valve spring with all of the worn shiny areas. Of course, people have been using the interference fit dual spring for 50+ years so it isn't like they are a really bad design. Just something to consider.
