Holley float adjustment
#2468267
03/18/18 08:07 PM
03/18/18 08:07 PM
Posts: 733 Northern Virginia
Moparmaniacc
Northern Virginia
My Holley 40458 is giving trouble. I couldn't adjust the secondary float level (counterclockwise to raise level) to be high enough to be just below the sight hole. Finally I got tired of trying to adjust it and took the back bowl off. The float was adjusted all the way against the bottom! So I turned it upside down, adjusted it so the float was level with the bottom, put it back together, and took it for a ride. Now the level is way too high. So I loosened the screw and turned the nut clockwise, again and again and again, and still the level is too high. What is going on? I could be wrong, but the nut never feels like it's engaging the needle to turn it. Why didn't my dry adjustment work? Did I bend the float tang?
Re: Holley float adjustment
[Re: Moparmaniacc]
#2468286
03/18/18 08:47 PM
03/18/18 08:47 PM
Posts: 18,157 Mass
DAYCLONA
Mass
This float is yellowish, almost orange, plastic float. No fuel in it. Hollow float or solid plastic?
[Re: Moparmaniacc]
#2468305
03/18/18 09:15 PM
03/18/18 09:15 PM
Posts: 25,748 Rio Linda, CA
John_Kunkel
Rio Linda, CA
I could be wrong, but the nut never feels like it's engaging the needle to turn it. Why didn't my dry adjustment work? The threads in the bowl might be stripped which would explain why it won't hold an adjustment or the needle valve isn't shutting off the fuel flow.
[Re: Moparmaniacc]
#2468306
03/18/18 09:15 PM
03/18/18 09:15 PM
Posts: 4,457 Washington
madscientist
Washington
You have to adjust the secondary side very slow. Especially lowering it. The secondary bowl uses fuel at a much slower rate.
If I'm in the same spot as you, I turn the engine off and drain a little fuel out of the bowl through the fuel screw. Enough so it's below the hole. Then turn the adjusting screw 1/2-3/4 turn down and start it again.
If it's still high, repeat. If it's low, adjust it up very slow and you'll get it.
[Re: Moparmaniacc]
#2468317
03/18/18 09:40 PM
03/18/18 09:40 PM
madscientist
Washington
The threads are not stripped, the nut has 2 flat spots in it. When it falls down too far, then the flat spots dont engage.
Silly question, is CW and CCW opposite directions from front to rear bowl? Same front to rear.
[Re: dogdays]
#2468659
03/19/18 05:04 PM
03/19/18 05:04 PM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
There's nothing wrong with bending the tab if you can't move the seat far enough to set fuel level.
R. Yep,that is an easy fix,all you need do is run the needle/seat in until you have about 1/16" exposed above the bowl,bend the tab until top of float is parallel with bowl and you will have all the adjustment you need up or down to get the correct float level.
[Re: Moparmaniacc]
#2468775
03/19/18 09:11 PM
03/19/18 09:11 PM
Posts: 5,080 organ
maximum entropy
organ
be sure to check your fuel pressure, also. try another needle/ seat assy. my favorite abbreviation, fwiw- assy. i always feel like i'm getting away with something. assy.
[Re: Moparmaniacc]
#2468928
03/20/18 03:34 AM
03/20/18 03:34 AM
Posts: 43,127 Bend,OR USA
Cab_Burge
Found a piece of gasket between needle and seat. Arghhh! Good find Easy fix huh
[Re: Moparmaniacc]
#2472555
03/26/18 11:44 PM
03/26/18 11:44 PM
Moparmaniacc
Northern Virginia
The gas is pouring from between the float setter hex and the adjusting screw, but - that's just the path of least resistance. The real problem is the bowl is too full of gas - no matter how much I adjust the float it doesn't make any difference. If I open the secondary sight screw it pours out there too. My best guess at this point is gas is pouring out a small hole in the gasket between the secondary metering block and the metering plate that screws to the block. My other theory is that one of the screws (not a hex screw, not like any screw I've ever seen) that holds the metering plate was loose, and gas is seeping past that screw. Either a bad gasket or a loose screw would render float adjustment useless, right? I gotta wait to find out if I'm right, 'cuz I couldn't take the gasket off in one piece, and had to order another one. Bigcar, you may be right, but remember I swapped in a whole new secondary bowl including the needle valve and the seat, so that would mean I had two bad needle and seats....not impossible, but not likely either.
