Shock Mounts for Lowered Cars or Trucks #2467678
03/17/18 11:31 AM
03/17/18 11:31 AM
E
earlymopar Offline OP
E
Just curious what others have done with your shock mounts when you have lowered your car or truck. With the factory mounting locations on a lowered car, the shock ends up at a steep (laid over) angle that makes them almost useless. I could obviously move the upper mount toward the outside of the car or move the bottom mount toward the center of the car but am looking for what other may have done. I hear of shock mounts that re-position the shock but have not seen them.
Thanks much,
- EM
Re: Shock Mounts for Lowered Cars or Trucks [Re: earlymopar] #2468013
03/18/18 10:08 AM
03/18/18 10:08 AM
The Netherlands
BigBlockMopar Offline
The Netherlands
Nothing.
Shocks don't change when you lower the rear end of a Mopar (with lowering blocks).
Re: Shock Mounts for Lowered Cars or Trucks [Re: BigBlockMopar] #2468020
03/18/18 10:29 AM
03/18/18 10:29 AM
E
E
Ha! They sure do. Most rear shocks are mounted at a slight angle and when you lower your car or truck, regardless of what method you use for lowering it, the shock angle increases or "lays-over" further. Often they lay over to a point that they do not work correctly. 30 degrees is the recommended maximum.
- EM
Re: Shock Mounts for Lowered Cars or Trucks [Re: earlymopar] #2468028
03/18/18 11:05 AM
03/18/18 11:05 AM
Guitar Jones Offline
See this is what happens around here when you try to help someone. It all depends on how you lower the car. If you use lowering blocks between the differential and the leaf spring all you are doing is moving the rear up higher in the chassis. The shock mount plate stays in the same position.
So maybe you should be more specific about what exactly you are doing and on what.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: Shock Mounts for Lowered Cars or Trucks [Re: earlymopar] #2468033
03/18/18 11:11 AM
03/18/18 11:11 AM
The Netherlands
The Netherlands
EM - You might want to crawl under your car to visualise things and recheck your statement.
The shock plates (and springs) get lowered the same amount the body is (Lowering blocks go in-between rear axle and leafsprings+shock-plates).
In short, it's only the rear axle that ends up higher 'in' the body/suspension, everything else stays the same.
edit:
Tree'd by the Guitar man smile
Re: Shock Mounts for Lowered Cars or Trucks [Re: BigBlockMopar] #2468043
03/18/18 11:33 AM
03/18/18 11:33 AM
BDW Online content
BDW  Online Content
And some simple math (trig) would show it would take a considered distance to change the slant angle of the shock significantly
I'd be surprised if it's even possible to lower enough to come anywhere near 30deg.
Re: Shock Mounts for Lowered Cars or Trucks [Re: earlymopar] #2468366
03/18/18 11:21 PM
03/18/18 11:21 PM
E
E
No need to visualize anything and I'm not using lowering blocks. The reality is that while the spring plate that the shock is attached to does not move, the upper shock mount moves downward with the vehicle height when it's lowered and when that happens the shock height compresses. This is how the shock angle increases. It's simple trig.
- EM
Re: Shock Mounts for Lowered Cars or Trucks [Re: earlymopar] #2468420
03/19/18 01:04 AM
03/19/18 01:04 AM
E
E
I found the solution I was after.
- EM
Re: Shock Mounts for Lowered Cars or Trucks [Re: earlymopar] #2468523
03/19/18 11:50 AM
03/19/18 11:50 AM
moparx Offline
moparx  Offline
- EM
and will/would you care to share this for future reference ?
beer
