Chrager front on a Magnum wagon? #246780
03/08/09 11:22 AM
03/08/09 11:22 AM
Kalispell Mt.
HotRodDave Offline OP
Kalispell Mt.
How hard would it be to put an 07 charger front end on a 07 magnum wagon? Do the body lines match up? anythin else different I might need toknow about?
Re: Chrager front on a Magnum wagon? [Re: HotRodDave] #246781
03/08/09 03:27 PM
03/08/09 03:27 PM
Tampa FL
hemibeep Offline
hemibeep  Offline
Tampa FL
try lxforums.com they will know
Re: Chrager front on a Magnum wagon? [Re: hemibeep] #246782
03/08/09 04:19 PM
03/08/09 04:19 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Go to the super market and find the car you want to get the clip off of.(Or the Dealership)
If the body lines match you should be good to go.
Re: Chrager front on a Magnum wagon? [Re: HotRodDave] #246783
03/08/09 04:28 PM
03/08/09 04:28 PM
Seminole County FL to Plymouth...
Barry70GTX Offline
Barry70GTX  Offline
It requires surgery. The body lines do not match.
NMCA NSS 67 Coronet
Re: Chrager front on a Magnum wagon? [Re: Barry70GTX] #246784
03/08/09 05:44 PM
03/08/09 05:44 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Kind figures too bad a charger wagon would be cool.
Re: Chrager front on a Magnum wagon? [Re: bboogieart] #246785
03/08/09 09:24 PM
03/08/09 09:24 PM
Barry70GTX Offline
Barry70GTX  Offline
It has been done though.Check it out.
http://www.lxforums.com/board/showthread.php?t=35148
NMCA NSS 67 Coronet
Re: Chrager front on a Magnum wagon? [Re: HotRodDave] #246786
03/08/09 10:05 PM
03/08/09 10:05 PM
Tampa , Fl
MoparJoe Offline
super gas
MoparJoe  Offline
super gas
Tampa , Fl
It takes a bit of metal work but its not impossible, theres 2 silver ones running around my area. The 300 nose is a bolt on, they make 300 wagons for outside the US but can't sell it here because the magnum is a truck and a 300 is a car.
