Page 3 of 3 1 2 3
Re: (Re)coating MLS gaskets prior to reuse [Re: Clanton] #2467381
03/16/18 04:13 PM
03/16/18 04:13 PM
Val-haul-ass... eventually
BradH Offline OP
BradH  Offline OP
FWIW, I have decided not to reuse the Mr. G MLS head gaskets. I have a few sets of the old DG composition "race" gaskets that never caused me any problems, other than being a PITA to clean up after disassembly.
Re: (Re)coating MLS gaskets prior to reuse [Re: BradH] #2467564
03/16/18 11:43 PM
03/16/18 11:43 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I'm on the 3rd time around on mine. BB, 15-1,-1 heads. Split them up, clean, copper coat and go.
Doug
Re: (Re)coating MLS gaskets prior to reuse [Re: dvw] #2467680
03/17/18 11:44 AM
03/17/18 11:44 AM
long time lurker, short time p...
P
PorkyPig Offline
PorkyPig  Offline
P
When people spray coat them is it only on the surfaces facing the block and heads? Or does each layer get coated?
Re: (Re)coating MLS gaskets prior to reuse [Re: PorkyPig] #2467695
03/17/18 12:13 PM
03/17/18 12:13 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I personally did them all.
Doug
Re: (Re)coating MLS gaskets prior to reuse [Re: BradH] #2467765
03/17/18 03:57 PM
03/17/18 03:57 PM
crabman173
crabman173
Guys
Coppercoat was made way back in the day as yes--a sort of sealer with the copper added to promote heat transfer with Steel Shim head gaskets
It is not the right product for the way you all seem to use it
The spray can Hylomar is the best head gasket sauce in the world--I have re-sprayed Cometics three/ four times and kept on using them--it restores the ability to seal the water--that is all it does
The Mr gasket multi layers suck!! Use Cometics or else
And if you do use steel shim gaskets the Hylomar is ten times better than CopperCoat--why don't you just use some Indian gasket sealer while you are at it
Re: (Re)coating MLS gaskets prior to reuse [Re: pittsburghracer] #2468531
03/19/18 12:02 PM
03/19/18 12:02 PM
Connecticut
FurryStump Offline
FurryStump  Offline
Connecticut
Originally Posted By pittsburghracer
Originally Posted By Al_Alguire
You drill out a rivet, not like its complicated. I would NEVER reuse thme without cleaning them. Only way to clean them properly is to drill out the rivet and separate them to clean them. Maybe its the difference between compression ratios above 15-1 but I have NEVER had an issue taking them apart and cleaning them, then using copper coat on the outer layers. I've never used a Mr Gasket or anyone else's MLS gasket except Cometic. But they will tell you to either NOT reuse them or to wipe em off and never use anything.
Heck I had to drill out 3 rivots and cut part of the gasket on my Keith Black block and B1 head combo. No big deal. The rivets wouldn't let my head seat properly.
I had to drill out one rivet on my small block x heads 360 block, the rivet got pinched between the head and block. Cometic gaskets. Caught it just as I was about to torque ut down!
best of 11.39 at 117 mph 1.60 60’. 68 340 S Barracuda Fastback F.A.S.T [IMG]http://i67.tinypic.com/2mnnnnt.jpg[/IMG]
Page 3 of 3 1 2 3
