Date coded plug wires.. #246742
03/08/09 11:03 AM
03/08/09 11:03 AM
3
340dart4spd Offline OP
Parts Problem
Parts Problem
3
My 70 Coronet R/T was build early April,I am wonder if I should use 1st Quarter or 2nd Quarter plug wires..Is one more correct then the other..? Or could it have been Either?? Thanks
Re: Date coded plug wires.. [Re: 340dart4spd ] #246743
03/08/09 01:30 PM
03/08/09 01:30 PM
Mass
charge70 Offline
charge70  Offline
Mass
If I was restoring your car,I would be using 1st quarter wires as the build of your car is to early into the 2nd quarter.Just my . John.
1970 Dodge Charger R/T S.E. 1969 Dodge Dart GTS 440 M-Code 1970 Dodge Charger 500 383/4-speed w/A.C.
Re: Date coded plug wires.. [Re: charge70] #246744
03/08/09 02:09 PM
03/08/09 02:09 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Really depends on the actual build date. With an April SBD it could have been 1st Q , 2nd Q or a mixture of the 2
Currently avail dates on dated plug wire sets are 1st or 3rd quarter of each succesive year only, at this time
Re: Date coded plug wires.. [Re: gtx6970] #246745
03/08/09 03:24 PM
03/08/09 03:24 PM
3
Parts Problem
Parts Problem
3
I think I read that somewhere in a thread..Thanks.. I bought a set of 1st Quarter ones..
