VIN numbers on motor and trans? #246698
03/08/09 08:49 AM
03/08/09 08:49 AM
Seattle, WA
3
375inStroke Offline OP
Special needs person
3
Seattle, WA
What's the deal with the motor and trans numbers? Did some plants put only the last 8 digits, and some the entire VIN number? I'm looking at a '69 Charger, and saw the entire VIN. I thought it was only the last 8 digits. What's up?
Re: VIN numbers on motor and trans? [Re: 375inStroke] #246699
03/08/09 10:12 AM
03/08/09 10:12 AM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
Many '69 model year Mopars had the entire VIN stamped on the eng/trans.
Re: VIN numbers on motor and trans? [Re: 70440+6bbl] #246700
03/08/09 10:15 AM
03/08/09 10:15 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Many , I rarely see 69 blocks and trans stamped with full vin , of all the 69 blocks I have only ONE had the full vin , that one I think was out of a charger 500 , I have a few transmissions and they are all early , prior to jan 69 , vin squences .
Re: VIN numbers on motor and trans? [Re: 375inStroke] #246701
03/08/09 10:18 AM
03/08/09 10:18 AM
3
340dart4spd Offline
Parts Problem
340dart4spd  Offline
Parts Problem
3
I am not 100% sure but I think prior to 68 they didn't stamp them....
Re: VIN numbers on motor and trans? [Re: 375inStroke] #246702
03/08/09 12:34 PM
03/08/09 12:34 PM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
I can't speak to all plants but since you have a Charger, you'd be interested what the St. Louis and Hamtrack plants did. From what I've seen, both plants used all 13 digits at least through late November. Early built 69's would have all of the VIN on the engine and tranny.
Seeking:
1969 St. Louis plant VINs, SPD, and VONs.
Over 2,000 thanks to you!
Re: VIN numbers on motor and trans? [Re: 375inStroke] #246703
03/09/09 11:14 AM
03/09/09 11:14 AM
Poplar Bluff, Mo. 63901
2
268RTs4ME Offline
268RTs4ME  Offline
68 blocks are usally stamped on motor back by oil sending unit 8 digits
