Big block oil pan pickup info #2466757
03/15/18 04:02 AM
03/15/18 04:02 AM
South Dakota
Mirada440 Offline OP
South Dakota
Anyone ever used one of these pans? What pickup works with them?
Re: Big block oil pan pickup info [Re: Mirada440] #2466758
03/15/18 04:06 AM
03/15/18 04:06 AM
South Dakota
South Dakota
Sorry having trouble getting a pic it's the assault pans on ebay stock chrome with baffles
Re: Big block oil pan pickup info [Re: Mirada440] #2466759
03/15/18 04:13 AM
03/15/18 04:13 AM
South Dakota
South Dakota
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F330354601881
Re: Big block oil pan pickup info [Re: Mirada440] #2466772
03/15/18 05:59 AM
03/15/18 05:59 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Looks like the sell the pickup right above the listing for $25.
Re: Big block oil pan pickup info [Re: Mirada440] #2466779
03/15/18 06:58 AM
03/15/18 06:58 AM
South Dakota
South Dakota
I looked but didn't see anything I seen was for it... was wondering if it worked with the stock c body pickup I have otherwise seems foolish to spend the money for it and a new pickup when for about $5-7 more you can get a 7qt pan and pickup!
Re: Big block oil pan pickup info [Re: Mirada440] #2466813
03/15/18 10:30 AM
03/15/18 10:30 AM
an8sec70cuda Offline
Chrome pans are a PITA...leaks.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Big block oil pan pickup info [Re: an8sec70cuda] #2466860
03/15/18 12:43 PM
03/15/18 12:43 PM
moparx Offline
moparx  Offline
iagree my experience with ALL chrome pans over the 50+ years i have been playing with these aggravating pieces of "stuff". biggrin this included all makes of engines and transmissions. i even went to all the usual fixes, sanding the chrome off the rails, flattening the rails, bolt hole "stiffeners, ALL kinds of gasket manufacturers [with the exception of SUPERFORMANCE], different RTV's [maybe i should try ATV'S ? laugh2] Right Stuff, and similar products with, and without, gaskets, you name it. if they don't leak at start up, just wait, it will, not taking long to start. re-tighten bolts, etc. so it comes down to stock pans and paint, or aluminum pans. just my experience. your mileage may vary.......
beer
