Thanks dayclona. Have you ever used those guys before? I was getting worried when I saw the only other offering was showcars!
I've used Unlimited in the past, fenders, hoods, etc for Mopar projects, their quality was very good, but they did have a bad turn down in quality several years ago, along with service, but they've been under new management for about 2-3 yrs now and things seem to be back on track, I bought a brand X hood off them about a year ago, and had no issues with it other than your avg amount of prep often required with fiberglass, if the 70 bolt on fenders are anything like the Cuda fenders I got from them, they will have all the flanges to mount them/wheel lip moldings/lower fender flange, headlights often require you glass in the metal support/bucket assy from your steel fenders, or buy their fiberglass buckets from them, or perhaps they may already be molded in?, call Kevin at Unlimited and ask
FYI: whatever your choice, don't use Showcars, pure crap, that's if you get your stuff...even then you don't want it!
Mike
