Airplane/aviation fuel #2465840
03/13/18 04:09 PM
03/13/18 04:09 PM
Keymar, MD
DusterKid Offline OP
Keymar, MD
Has anyone ever ran Airplane/aviation fuel in the car? There's a old timer at the track that does it and swears by it. He does run a Chevy that is about a 11:1 engine. I did some looking online and 99.9% of the things I read say not to. Just curious the affects that it would cause by running it.
Re: Airplane/aviation fuel [Re: DusterKid] #2465869
03/13/18 04:50 PM
03/13/18 04:50 PM
Norfolk, NE
Racer33 Offline
Racer33  Offline
Norfolk, NE
Run it in several vehicles from street cars to race cars. Started using it when I had some left over from my Lycoming powered airboat. Many race gas manufactures use or used it as the base for the fuels they sell. My airport only allows me to carry fuel jugs into the pump and carry them out so I don't usually buy more then 15 gallons at a time. The pump is a just a self service credit card type pump. I even run my small engines on it before I park them for seasonal storage. Remember it is leaded fuel and will effect oxygen sensors if you are using them.
Re: Airplane/aviation fuel [Re: DusterKid] #2465893
03/13/18 05:37 PM
03/13/18 05:37 PM
Keymar, MD
Keymar, MD
do you run the 100LL or JetA?
Re: Airplane/aviation fuel [Re: DusterKid] #2465899
03/13/18 05:51 PM
03/13/18 05:51 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Leaded fuel has lead and new engines have sensors
and the will quit.. thats the big factor..if you
run O2 sensors... dont bother
(LL is low lead)
wave
Re: Airplane/aviation fuel [Re: DusterKid] #2465904
03/13/18 05:52 PM
03/13/18 05:52 PM
AndyF Offline
AndyF  Offline
It works okay in most applications but you have to watch out for the lead. It will kill O2 sensors over time. It also changes the way you read plugs. I don't think I'd use it in a serious race engine but I know lots of guys who mix it with unleaded to give an old muscle car a little more octane.
Re: Airplane/aviation fuel [Re: DusterKid] #2465917
03/13/18 06:25 PM
03/13/18 06:25 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Jet fuel (there's variants, but a very common one is known as Jet A) is really close to regular old diesel fuel. And, for that matter, kerosene. You can even run it straight in your diesel car or truck, though it doesn't lubricate as well so if you do, you'd want to add some sort of lubrication additive.
Re: Airplane/aviation fuel [Re: DusterKid] #2465918
03/13/18 06:27 PM
03/13/18 06:27 PM
Norfolk, NE
Racer33 Offline
Racer33  Offline
Norfolk, NE
I run 100 low lead
Re: Airplane/aviation fuel [Re: CSK] #2465932
03/13/18 06:51 PM
03/13/18 06:51 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Jet fuel isnt made for your auto style engine..
you DONT want that
wave
Re: Airplane/aviation fuel [Re: DusterKid] #2465954
03/13/18 07:22 PM
03/13/18 07:22 PM
Ontario, Canada
Stanton Online content
Don't question me!
Stanton  Online Content
Don't question me!
Ontario, Canada
First hand experience ... avgas has a different specific gravity than regular pump gas because it has to work at high altitudes. Subsequently using even a 10% mixture of avgas will necessitate a float adjustment. So that's fine and dandy as long as you always run whatever mixture you decide on. BUT, if you ever change the mixture and don't adjust your floats, the car will run like absolute CRAP. Personally I didn't see any benefit and it was a big hassle.
Re: Airplane/aviation fuel [Re: DusterKid] #2465969
03/13/18 07:49 PM
03/13/18 07:49 PM
K
KOS Offline
KOS  Offline
K
I've been running it for 25yrs+ great fuel lots of serious guys running it go over to yellowbullet to get some real advice.you can run it straight up to 13.1 ish then after that add some MMT to it.google it
Re: Airplane/aviation fuel [Re: DusterKid] #2465990
03/13/18 08:26 PM
03/13/18 08:26 PM
Minnesota, USA
humpty Offline
humpty  Offline
Minnesota, USA
I’ve been running it for a few years with no issues - 12:1 compression. It’s usually pretty accessible and a lot cheaper than 110 race gas (up here in the Midwest anyway). I paid $4.50/gal last fall.
We dyno’d a blown small block with it and made 725hp with no detonation.
As previously mentioned - I’d stay clear if you’re running an O2 sensor.
Re: Airplane/aviation fuel [Re: DusterKid] #2466006
03/13/18 08:47 PM
03/13/18 08:47 PM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
It's true that 100LL has lower density than most pump fuels. However that is also true of many race fuels.
Temperature plays a role in density specs but here's some published numbers to give some idea of the variations.
Specific gravities
100LL, 0.714 to .719
Pump Gas .74 typical
Sunoco GT .734
Sunoco GTX .764
Sunoco Standard .729
VP Vintage leaded .715
VP C9 .718
VP Blaze 100 .746
Race fuel info came from Sunoco Race Fuels and VP websites.
Pump Gas came from CRC E67 fuel Study (Durbin et al) and similar sources.
Av Gas from Fuel Mfc. Bulletins eg. Shell Au 100LL pdf
Distilation curve falls between typical street fuels and the race fuels I looked at. Posted a graph here:
https://www.tapatalk.com/groups/racingfu...579.html#p12657
Re: Airplane/aviation fuel [Re: Mattax] #2466034
03/13/18 09:29 PM
03/13/18 09:29 PM
Specific gravities
Sunoco GT .734
Sunoco GTX .764
VP C9 .718
VP Blaze 100 .746
I've used and tested 100 LL for a long time, I bought my first airplane in 1989. I've never used or tested 100LL from east of the rocky mountains so I'm not sure how 100 LL from there would test as far as specific gravity, all of the 100 LL I've tested has been right at .690, never above including when sitting during the winter in the airplane fuel cells inside the hangar shruggy
I use to buy and use 115-135 Avaition and even some 130-145 octane aviation fuel back when the airlines still used big HP piston engines in their airplanes, that stuff had a lot of lead in it shruggy
As far as the additives used in 100 LL it has a standard shelf life of up to 18 monthes up Todays pump swill usually has 90 days max life exposed to air n your car tank shruggy
OP as far as using 100LL in a race car be prepared to change your jetting, spark plug heat range and ignition timing to make the motor not hurt itself on 100LL scope twocents
E85 is a much better choice in my opinion for todays world of drag racing work scope
Re: Airplane/aviation fuel [Re: DusterKid] #2466049
03/13/18 09:56 PM
03/13/18 09:56 PM
Tucson AZ.
RADAMX Offline
RADAMX  Offline
Tucson AZ.
I have used it in the past a lot.
Even dynoed engines with it .
No problems even with my O2s. But I was willing to sacrifice a sensor or two if need be.
made over 950hp with spray with no problems.
At 1162 hp I did see some specs on the plug so at that point I stepped up to VP NOS .
All and all it is a good fuel if you can still get it.
Will require a jet change though
Re: Airplane/aviation fuel [Re: Cab_Burge] #2466054
03/13/18 10:03 PM
03/13/18 10:03 PM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
Cab, That's very interesting. Maybe some of the other aviation guys will chime in on the density. I also looked at BP & Exxon but that was a while back and did not take notes about temperature or methods or if they were even mentioned.
Bottom line does seem to be that jetting will likely need to be adjusted for optimum performance. Probably true for most any change in fuel.
Re: Airplane/aviation fuel [Re: DusterKid] #2466082
03/13/18 10:56 PM
03/13/18 10:56 PM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
I run it Down Under when ever I get the chance, our cars seem to run better on it, 2 mph last time i changed over.
1963 Plymouth Max Wedge
1971 Barracuda
Re: Airplane/aviation fuel [Re: DusterKid] #2466304
03/14/18 12:09 PM
03/14/18 12:09 PM
Keymar, MD
Keymar, MD
For the jet changes, is it typically take a larger or smaller jet?
Re: Airplane/aviation fuel [Re: DusterKid] #2466358
03/14/18 01:51 PM
03/14/18 01:51 PM
Tucson AZ.
RADAMX Offline
RADAMX  Offline
Tucson AZ.
Its been awhile but i think it was 2-4 larger
Of course you will need to Check your plugs for the tune up
Re: Airplane/aviation fuel [Re: AndyF] #2466405
03/14/18 03:08 PM
03/14/18 03:08 PM
Weatherford, Texas
RapidusMaximus Offline
Weatherford, Texas
X2...this is the way I run it in my GTX, seems to work fine, been running it this way for the last year or so..."seat of the pants" feel tells me it pulls a little harder than straight super unleaded...and the exhaust aroma is an added benefit laugh2
1968 Plymouth GTX
1974 Dodge P/U Long Bed Stepside 318
2019 Ram 2500 6.4, auto, 4WD
Re: Airplane/aviation fuel [Re: DusterKid] #2466418
03/14/18 03:35 PM
03/14/18 03:35 PM
an8sec70cuda Online content
an8sec70cuda  Online Content
I ran 100LL AvGas for a long time in a 12:1 440 street/strip combo. Ran great and never hurt anything.
Know a local guy that ran it for YEARS in a 13:1 BB Chevy w/ 2 stages of nitrous. One of those guys that bought up leftover parts people were scared to run, but built an engine out of them that ran for years...too cheap to buy race fuel, so he always ran Avgas. Worked great for him.
This is one of those subjects that 99% of the people telling you not to run it have zero experience w/ it and are just repeating hearsay.
CHIP
'06 GMC 2500HD LBZ Duramax
