Re: Airplane/aviation fuel
[Re: DusterKid]
#2465899
03/13/18 05:51 PM
03/13/18 05:51 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Leaded fuel has lead and new engines have sensors and the will quit.. thats the big factor..if you run O2 sensors... dont bother (LL is low lead)
[Re: DusterKid]
#2465917
03/13/18 06:25 PM
03/13/18 06:25 PM
Posts: 2,872 Pattison Texas
CSK
Pattison Texas
do you run the 100LL or JetA? Jet fuel (there's variants, but a very common one is known as Jet A) is really close to regular old diesel fuel. And, for that matter, kerosene. You can even run it straight in your diesel car or truck, though it doesn't lubricate as well so if you do, you'd want to add some sort of lubrication additive.
[Re: DusterKid]
#2466006
03/13/18 08:47 PM
03/13/18 08:47 PM
Posts: 1,645 Phila. Pa.
Mattax
Phila. Pa.
It's true that 100LL has lower density than most pump fuels. However that is also true of many race fuels. Temperature plays a role in density specs but here's some published numbers to give some idea of the variations. Specific gravities 100LL, 0.714 to .719 Pump Gas .74 typical Sunoco GT .734 Sunoco GTX .764 Sunoco Standard .729 VP Vintage leaded .715 VP C9 .718 VP Blaze 100 .746 Race fuel info came from Sunoco Race Fuels and VP websites. Pump Gas came from CRC E67 fuel Study (Durbin et al) and similar sources. Av Gas from Fuel Mfc. Bulletins eg. Shell Au 100LL pdf Distilation curve falls between typical street fuels and the race fuels I looked at. Posted a graph here: https://www.tapatalk.com/groups/racingfu...579.html#p12657
[Re: Mattax]
#2466034
03/13/18 09:29 PM
03/13/18 09:29 PM
Posts: 43,303 Bend,OR USA
Cab_Burge
It's true that 100LL has lower density than most pump fuels. However that is also true of many race fuels. Temperature plays a role in density specs but here's some published numbers to give some idea of the variations. Specific gravities 100LL, 0.714 to .719 Pump Gas .74 typical Sunoco GT .734 Sunoco GTX .764 Sunoco Standard .729 VP Vintage leaded .715 VP C9 .718 VP Blaze 100 .746 Race fuel info came from Sunoco Race Fuels and VP websites. Pump Gas came from CRC E67 fuel Study (Durbin et al) and similar sources. Av Gas from Fuel Mfc. Bulletins eg. Shell Au 100LL pdf Distilation curve falls between typical street fuels and the race fuels I looked at. Posted a graph here: https://www.tapatalk.com/groups/racingfu...579.html#p12657 I've used and tested 100 LL for a long time, I bought my first airplane in 1989. I've never used or tested 100LL from east of the rocky mountains so I'm not sure how 100 LL from there would test as far as specific gravity, all of the 100 LL I've tested has been right at .690, never above including when sitting during the winter in the airplane fuel cells inside the hangar ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) I use to buy and use 115-135 Avaition and even some 130-145 octane aviation fuel back when the airlines still used big HP piston engines in their airplanes, that stuff had a lot of lead in it ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) As far as the additives used in 100 LL it has a standard shelf life of up to 18 monthes ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) Todays pump swill usually has 90 days max life exposed to air n your car tank ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) OP as far as using 100LL in a race car be prepared to change your jetting, spark plug heat range and ignition timing to make the motor not hurt itself on 100LL ![twocents twocents](/ubbthreads/images/graemlins/custom/twocents.gif) E85 is a much better choice in my opinion for todays world of drag racing
[Re: Cab_Burge]
#2466054
03/13/18 10:03 PM
03/13/18 10:03 PM
Mattax
Phila. Pa.
Cab, That's very interesting. Maybe some of the other aviation guys will chime in on the density. I also looked at BP & Exxon but that was a while back and did not take notes about temperature or methods or if they were even mentioned.
Bottom line does seem to be that jetting will likely need to be adjusted for optimum performance. Probably true for most any change in fuel.
[Re: DusterKid]
#2466082
03/13/18 10:56 PM
03/13/18 10:56 PM
Posts: 1,096 Australia
ozymaxwedge
Australia
I run it Down Under when ever I get the chance, our cars seem to run better on it, 2 mph last time i changed over.
1963 Plymouth Max Wedge 1971 Barracuda
[Re: DusterKid]
#2466358
03/14/18 01:51 PM
03/14/18 01:51 PM
Posts: 235 Tucson AZ.
RADAMX
Tucson AZ.
For the jet changes, is it typically take a larger or smaller jet? Its been awhile but i think it was 2-4 larger Of course you will need to Check your plugs for the tune up
[Re: AndyF]
#2466405
03/14/18 03:08 PM
03/14/18 03:08 PM
Posts: 2,412 Weatherford, Texas
RapidusMaximus
Weatherford, Texas
It works okay in most applications but you have to watch out for the lead. It will kill O2 sensors over time. It also changes the way you read plugs. I don't think I'd use it in a serious race engine but I know lots of guys who mix it with unleaded to give an old muscle car a little more octane. X2...this is the way I run it in my GTX, seems to work fine, been running it this way for the last year or so..."seat of the pants" feel tells me it pulls a little harder than straight super unleaded...and the exhaust aroma is an added benefit ![laugh2 laugh2](/ubbthreads/images/graemlins/custom/laugh2.gif)
1968 Plymouth GTX 1974 Dodge P/U Long Bed Stepside 318 2019 Ram 2500 6.4, auto, 4WD
[Re: DusterKid]
#2466418
03/14/18 03:35 PM
03/14/18 03:35 PM
Posts: 13,402 Marion, South Carolina [><]
an8sec70cuda
I ran 100LL AvGas for a long time in a 12:1 440 street/strip combo. Ran great and never hurt anything. Know a local guy that ran it for YEARS in a 13:1 BB Chevy w/ 2 stages of nitrous. One of those guys that bought up leftover parts people were scared to run, but built an engine out of them that ran for years...too cheap to buy race fuel, so he always ran Avgas. Worked great for him.
This is one of those subjects that 99% of the people telling you not to run it have zero experience w/ it and are just repeating hearsay.
