Re: How far down should coupler slip over steering shaft?
[Re: Blakcharger440]
#246586
03/08/09 02:16 AM
03/08/09 02:16 AM
Posts: 3,683 South San Francisco, Ca
70sixpkrt
Far enough that you can install the roll pin. I had to use a metal punch thru the roll pin hole and wiggle the coupler down enough to install the roll pin. I just looked at mine and the end of the bottom spline is even with the end of the coupler. By the way, which steering box did you end up getting?
#246589
03/08/09 11:17 AM
03/08/09 11:17 AM
Posts: 3,905 Minnesota
3twos
Minnesota
Here is what my cuda looks like, you can still see the splines, about 1/4" of them.
Al & Sheila
[Re: 70sixpkrt]
#246590
03/08/09 11:38 AM
03/08/09 11:38 AM
Posts: 15,491 the boonies
aarcuda
the boonies
and the shaft should be set so the H blacks are midway into the coupler
[Re: 3twos]
#246592
03/08/09 07:36 PM
03/08/09 07:36 PM
Posts: 1,534 Florida
CHRGR69
BTW whats the best way to crimp down the cover on the steering coupler? PITA! 69 Charger P/S.
Grandma always said I had "hands of gold"!
