6.1L: Cam choices #2465225
03/12/18 02:53 PM
03/12/18 02:53 PM
MI, USA
moparmitch Offline OP
MI, USA
Hello all,
I bought myself a low mileage 6.1L as Christmas present to myself last December - cool!
I'm going to disassemble the motor and check everything out and figured I would consider swapping the cam, valve springs, and pushrods (maybe lifters) while it is apart.
Maybe not worth it as stock setup can't be improved upon? IDK...
Cam suggestions appreciated - shelf or custom? (max lift and duration with stock pistons)
Is it OK to re-use the rod bolts? I don't want to pay for a resize with ARP bolts. (just get new replacement bolts from Mopar?)
Anyway, motor will be going into a lighter car (approximately 2700lbs) with a 727 behind it.
Haven't decided yet on a Holley carb/drag pack intake or Holley EFI/stock 6.1 intake to deliver fuel. Hope this doesn't affect the cam choice too much...
Thanks!
Re: 6.1L: Cam choices [Re: moparmitch] #2465247
03/12/18 03:29 PM
03/12/18 03:29 PM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
Don't reuse the rod bolts.
Stock lift I think is .571 intake .557 exhaust (please correct me if I'm wrong),
biggest cam I ever installed in a stock 6.1 is Howards Cams 786155-14 Lift: .575 / .575, Duration @ .050: 213 / 219, Centerline: 110, not sure how much bigger you can go with stock pistons.
Re: 6.1L: Cam choices [Re: moparmitch] #2465251
03/12/18 03:33 PM
03/12/18 03:33 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
you cant resize the powdered metal rods unless you can find a bearing with a bigger outer diameter.
Re: 6.1L: Cam choices [Re: moparmitch] #2465330
03/12/18 06:24 PM
03/12/18 06:24 PM
MI, USA
MI, USA
Thanks for the info guys, much appreciated...
Re: 6.1L: Cam choices [Re: moparmitch] #2465585
03/13/18 12:53 AM
03/13/18 12:53 AM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
Sounds like the perfect opportunity to put a drop in set of pistons/rods
Re: 6.1L: Cam choices [Re: moparmitch] #2467845
03/17/18 08:16 PM
03/17/18 08:16 PM
MI, USA
MI, USA
If dropping in the rods and pistons, may as well get a stroker crank too...4.050 or 4.25. I'll start a new topic to discuss stroke options.
Thanks to all!
