Re: 727 trans vent relocation
[Re: crash520]
#2465127
03/12/18 10:58 AM
03/12/18 10:58 AM
Posts: 13,185 aZLiViN
J_BODY
aZLiViN
https://www.forbbodiesonly.com/moparforum/threads/727-torqueflite-rear-vent-install-question.146442/nice lil discussion with pictures and everything... I use the same "quick connect" discussed in this thread. The trans in my old Mirada was the plastic push in vent and never leaked a drop. My current trans will push fluid out during a pass, thus the catch can was installed. I've also noted the current vent is not in the same location as what the Mirada had. Believe it was the same as the picture noted in the link.
[Re: crash520]
#2465209
03/12/18 02:31 PM
03/12/18 02:31 PM
Posts: 11,530 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Back of the case so that it is open to the cavity under the rear support. I like it at 11 o'clock above the bolt hole on top left as long as there is not a clearance issue. Just below the bolt hole would be my second choice.
[Re: RTSE4ME]
#2465296
03/12/18 05:09 PM
03/12/18 05:09 PM
Posts: 11,684 W. Kentucky
justinp61
W. Kentucky
When I built my 904 John Cope told me not to add a rear vent. It was also mentioned in the link Cope no longer vents at the rear. When I added my trans brake I was told if I drilled the piston (I did) instead of the drum I wouldn't need to relocate the vent. Guess what? It blew fluid out the factory vent so the transmission had to come back out and partially apart to move it.
[Re: crash520]
#2465375
03/12/18 07:55 PM
03/12/18 07:55 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Done many, never had one leak where I put them.
[Re: RTSE4ME]
#2465446
03/12/18 09:54 PM
03/12/18 09:54 PM
Posts: 1,557 New Smyrna Beach FL
scottb
New Smyrna Beach FL
When I built my 904 John Cope told me not to add a rear vent. It was also mentioned in the link Cope no longer vents at the rear. That is what Joe at tranz act told me to not to move it to the back
[Re: crash520]
#2467043
03/15/18 07:54 PM
03/15/18 07:54 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Normally the stock vents don't leak, but I never say never. I've never had one leak at the rear and I've taken brakes out and put regular manual units in without plugging it. I wouldn't put a vent in the rear with a governor still in it. BUT If the guys who do it all day, everyday say not to move it, they have a reason and I'm not going to argue with them.
[Re: crash520]
#2467053
03/15/18 08:17 PM
03/15/18 08:17 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
My advice is to be cautious of drilling the case close to the sealing surface. Then be even more careful tightening the tapered pipe fitting with the hole so close to the case edge/ sealing surface.
