Page 2 of 4 1 2 3 4
Re: Pro Comp BB Victor CNC heads [Re: fast68plymouth] #2463995
03/09/18 09:00 PM
03/09/18 09:00 PM
So. Burlington, Vt.
fast68plymouth Offline OP
So. Burlington, Vt.
One thing I will say I'm not thrilled with, which I see with BBM heads pretty otten, is the chambers extend out beyond normal head gaskets.
My recommendation would be to use a Cometic 4.500 at a minimum to be sure the fire ring is clear of the edge of the chamber.
Remachined seats
Remachined seats & blended bowl
Re: Pro Comp BB Victor CNC heads [Re: fast68plymouth] #2464040
03/09/18 09:42 PM
03/09/18 09:42 PM
P
Porter67 Offline
Porter67  Offline
P
Thanks for taking the time to post on a not so popular brand of head, feedback from the pros is very helpful to some weather good or bad.
Re: Pro Comp BB Victor CNC heads [Re: fast68plymouth] #2464312
03/10/18 03:38 PM
03/10/18 03:38 PM
So. Burlington, Vt.
So. Burlington, Vt.
Just for grins I went on ebag to see where the current prices are for these things.
Looks like it's right about $1500/pr bare, $1800/pr assembled with HR springs, free shipping.
It would be interesting to see what the valve job situation was like between the bare and assembled heads.
Re: Pro Comp BB Victor CNC heads [Re: fast68plymouth] #2464364
03/10/18 05:31 PM
03/10/18 05:31 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Originally Posted By fast68plymouth
These are still std port window, and are easily the cheapest way I can think of to get to 350cfm with that sized opening.
I know a couple of ways that AREN'T the cheapest! laugh2
Re: Pro Comp BB Victor CNC heads [Re: fast68plymouth] #2464641
03/11/18 11:11 AM
03/11/18 11:11 AM
P
Porter67 Offline
Porter67  Offline
P
You can buy bulk china man products from here and skip the middle man, some of the places show there facilites some dont in there info.
Weather some agree with me or not but ALOT of the products sold with there cnc name in them is alot of hype and smoke and mirrors as at the end of the day most are just cleaned up checked china based products.
https://www.alibaba.com/trade/search?fsb...mopar+440+heads
Re: Pro Comp BB Victor CNC heads [Re: fast68plymouth] #2464644
03/11/18 11:25 AM
03/11/18 11:25 AM
P
Porter67 Offline
Porter67  Offline
P
$200-$300 per assembeled
https://www.alibaba.com/product-detail/N....15027a88hg7cnZ
Non cnc
I know procomp buys then non cnc from china and sends them up the street from them to have it done.
If one had there own cnc program...hmm. Then again time vs labor some of the cnc work is a bit cosmetic imo.
Re: Pro Comp BB Victor CNC heads [Re: fast68plymouth] #2464650
03/11/18 11:38 AM
03/11/18 11:38 AM
P
Porter67 Offline
Porter67  Offline
P
Not sure how these differ?
Look like the same specs, crazy site to search on.
https://www.alibaba.com/product-detail/P....4973701afrk7BH
Re: Pro Comp BB Victor CNC heads [Re: Porter67] #2465288
03/12/18 04:54 PM
03/12/18 04:54 PM
BradH Offline
BradH  Offline
I didn't spend much time digging thru your links, but what I see looks like the Edelbrock Performer RPM clones, not the Victor-style heads Dwayne showed above.
Re: Pro Comp BB Victor CNC heads [Re: fast68plymouth] #2468737
03/19/18 07:52 PM
03/19/18 07:52 PM
Sydney Australia
sr440 Offline
sr440  Offline
Sydney Australia
If you look hard enough the cnc versions can be bought for about $1240 per pair. Consider that Hughes want about $1550 just for the cnc program.Not bashing Hughes. Im sure their heads will easily outflow the Procomp version, but as a budget option the Procomps are looking good.
Re: Pro Comp BB Victor CNC heads [Re: fast68plymouth] #2484589
04/18/18 12:35 PM
04/18/18 12:35 PM
So. Burlington, Vt.
So. Burlington, Vt.
I just figured I'd post the final details of this job.
These heads use valves the same length as Indy heads, and I used 2.19/1.81 valves in this set.
After remachining the valve seats the installed height came out right at 1.900 with a .060 spring cup and a Comp Cams 10* steel retainer with std height locks.
Ti retainers could gain you about .030"-.050" depending on what brand and part number you used.
The chamber volume was right at 82cc, again..... This is after cutting the seats.
The decision was made to shoot for 72cc.
I guesstimated about .0055" per CC, so I cut them .055".
As it turned out, that was worth 12cc, so they ended up at 70cc's.
I took .066" off the intake surface to get the manifold to fit correctly.
Mocked up on an uncut 440 block with .040 head gaskets and Superformance .062" thick manifold gaskets, the bolt holes and ports lined up pretty well.
The 6412 std port intake gaskets are a pretty good match for the port sizing and alignment with these heads.
Heads are assembled with Comp 928 springs, 749 retainers, 611 locks, , steel jacketed viton valve seals, and 1.680 OD spring cups(which required no machining to fit).
Re: Pro Comp BB Victor CNC heads [Re: fast68plymouth] #2484658
04/18/18 03:32 PM
04/18/18 03:32 PM
Spring Valley ,Ca.
moparsquid Offline
moparsquid  Offline
Spring Valley ,Ca.
I have these same heads after dropping 3 valves I had to re do them valve guides, spring seats. they seem to be very good heads for my use other than the bigger intake boss
Re: Pro Comp BB Victor CNC heads [Re: moparsquid] #2484741
04/18/18 06:38 PM
04/18/18 06:38 PM
So. Burlington, Vt.
So. Burlington, Vt.
kinda like these;
https://board.moparts.org/ubbthreads/ubbt...tml#Post2319050
Re: Pro Comp BB Victor CNC heads [Re: fast68plymouth] #2484767
04/18/18 07:44 PM
04/18/18 07:44 PM
BradH Offline
BradH  Offline
Did cutting them that much regain anything in lost quench pad due to the extensive CNC carving in the chamber?
If they stay together, those could be some pretty effective flat-tappet cam heads.
Re: Pro Comp BB Victor CNC heads [Re: BradH] #2484849
04/18/18 10:26 PM
04/18/18 10:26 PM
So. Burlington, Vt.
So. Burlington, Vt.
Not really.....the chambers didn’t appear to shrink from the sides with that amount of milling.
Re: Pro Comp BB Victor CNC heads [Re: fast68plymouth] #2484992
04/19/18 10:28 AM
04/19/18 10:28 AM
an8sec70cuda Offline
You do some beautiful work Dwayne.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Pro Comp BB Victor CNC heads [Re: fast68plymouth] #2486217
04/21/18 10:50 PM
04/21/18 10:50 PM
Granbury TX
Prochargedmopar Offline
Granbury TX
Good info.
I enjoyed reading this thread.
"Old" member Registered: Sep 2001
Lost my credentials, I'm Back!! LOL
71 Ply Satellite Procharged
73 Dodge Dart Swinger
73 Ford F-100 390/Sniper efi/back to carb
01 Town and Country Limited
08 Dodge 2500 6.7 5" Deleted
02 Mercedes C230K
19 Camry
Re: Pro Comp BB Victor CNC heads [Re: fast68plymouth] #2486229
04/21/18 11:27 PM
04/21/18 11:27 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Thank you Dwayne for sharing !!!!
Re: Pro Comp BB Victor CNC heads [Re: fast68plymouth] #2558196
10/03/18 12:18 PM
10/03/18 12:18 PM
So. Burlington, Vt.
So. Burlington, Vt.
(It would appear the post that I’m responding to here has been deleted.
Apparently the rocker shaft fit in the saddles is a bit loose, and the poster was unhappy that I didn’t catch that when prepping the heads........ so this was my response to that.
I figure if this is a potential problem with these heads, then that’s info that should be out there, so I’ll leave my response up to highlight the fact that this is something that should be looked at.)
I’m the “head specialist” in question........ if you’re referring to the particular heads in this thread.
There isn’t really any excuse for not catching this issue, other than to say it’s something I’ve never come across on any Mopar head I’ve put on a motor in 38 years.
Frankly, the shaft saddles not being machined to the correct size never entered my mind.
Also, just the be clear........ I didn’t sell these heads.
I was contacted about whether I’d be interested in prepping a set of these heads, so I said “sure”........ and a few weeks later the cnc’d bare castings showed up.
To my recollection, I never had the rocker gear here that was going to be used on these heads to test fit any of it.
If the saddles are simply machined to a slightly larger diameter than they should be, you should be able to lay some shim stock in there to properly locate the shafts.
And if the hold down clamps are machined to the correct diameter, I would think it should work fine.
Another possible solution would be to contact Mike at B3RE to see about having some shaft relocation spacers made, with the lower arc of the spacer made to match your heads.
He’d likely instruct you that you need the spacers anyway, so it would just be a matter of whether he could match the arc of those saddles or not.
Re: Pro Comp BB Victor CNC heads [Re: fast68plymouth] #2558253
10/03/18 02:17 PM
10/03/18 02:17 PM
New Smyrna Beach FL
scottb Offline
scottb  Offline
New Smyrna Beach FL
Always 2 sides of the story this is what happens when you try to save some money on buying the oversea casting compared to the ones made here sometimes the cheap stuff never works out
Re: Pro Comp BB Victor CNC heads [Re: fast68plymouth] #2558264
10/03/18 02:34 PM
10/03/18 02:34 PM
So. Burlington, Vt.
So. Burlington, Vt.
If I’m not mistaken, I believe two different competitors in the EMC have used these castings for their entries in the past.
I wonder if their heads had this issue........ and if they did, how they worked around it.
Page 2 of 4 1 2 3 4
