Re: Power Valve Gasket
[Re: DusterKid]
#2463852
03/09/18 05:15 PM
03/09/18 05:15 PM
Posts: 11,530 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
An O-ring should have a counter sink in the metering block to retain it and keep it from squeezing out of place. I would use an O-ring over if it's not damaged. There are also plastic/nylon gaskets available that can be reused. I would think they would not be interchangeable due to the metering block. Just have to look at it.
