Re: holley billet metering block and emulsion jet question
[Re: dartman366]
#2468338
03/18/18 10:29 PM
03/18/18 10:29 PM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
Well,, it's on the car and running,,,and quite well I might add, once I got the float level set which was a little high and started to work with the curb idle screw's it came around quite nicely and sounds a lot crisper, idle tip in is smooth and there is no more blubbering like the other one(which I think I found the problem there) just smooth as silk up to the point the boosters took over, the other one sounded like it was loaded up a little and then would clean up so that is a big plus,, got it up to running temp for a while then shut it off,, let it sit for about 10 minutes and reached in and hit the start button and it was running and never touched the pedal,,,now for the tracks to open and start to dial this thing in. and also a big thank you to Dom for bailing me out with good straight forward no BS answers and tech advise. This is what I like to hear and now the tuning will begin but kudos to you for tackling what some consider too hard or impossible to do and I get it..........
[Re: BradH]
#2469126
03/20/18 02:15 PM
03/20/18 02:15 PM
Thumperdart
State of confusion
I THINK this one is the 1.610 bore and 1 3/4 blades but shipped so many lately I forgot...........
[Re: Thumperdart]
#2469419
03/20/18 10:48 PM
03/20/18 10:48 PM
dartman366
Mt. Vernon, Ohio
Well,, it's on the car and running,,,and quite well I might add, once I got the float level set which was a little high and started to work with the curb idle screw's it came around quite nicely and sounds a lot crisper, idle tip in is smooth and there is no more blubbering like the other one(which I think I found the problem there) just smooth as silk up to the point the boosters took over, the other one sounded like it was loaded up a little and then would clean up so that is a big plus,, got it up to running temp for a while then shut it off,, let it sit for about 10 minutes and reached in and hit the start button and it was running and never touched the pedal,,,now for the tracks to open and start to dial this thing in. and also a big thank you to Dom for bailing me out with good straight forward no BS answers and tech advise. This is what I like to hear and now the tuning will begin but kudos to you for tackling what some consider too hard or impossible to do and I get it.......... Well it took me two and a half solid days to do it and several times I had to walk away from it for a while,,, but I guess persistance paid off, or maybe it's just stubborness.LOL
[Re: dartman366]
#2469795
03/21/18 04:41 PM
03/21/18 04:41 PM
Thumperdart
State of confusion
I do that DAILY..............LOL
[Re: Thumperdart]
#2470087
03/21/18 11:05 PM
03/21/18 11:05 PM
Posts: 1,675 Mi.
G-Money1320
Mi.
Yes you are correct Brad. I just have a small 416 though. A lot of phone time and I believe Dom has me where I need to be!
416 stroker from Nick at Compu-flow. 11.14 in full street trim. Seems like a new best every time out. 11.06 open headers----so far!!
[Re: Mattax]
#2477740
04/05/18 06:07 AM
04/05/18 06:07 AM
Posts: 3,281 West Coast, USA
jbc426
West Coast, USA
Finally had the plate off, and the jets are above the fuel. Can I just drill and tap them into the lower hole? Or should I get a different metering block from someone who knows how to set one up?
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
